Go to Post [I] [/I]I think this may be some kind of record. We got through 9 entire posts before someone mangled the spelling of mecanum. [I] [/I] - Ether [more]
Unread 21-01-2015, 17:05
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
Rookie Year: 2013
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Python: button no attribute to wpilib ?
Hi! We are trying to use a joystick button with wpilib.buttons.JoystickButton but we keep getting a "buttons has no attribute to wpilib". We really need help on this because we would love to use pneumatics. We are using python and robotpy. Any help would be greatly appreciated!
Unread 21-01-2015, 17:14
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: Python: button no attribute to wpilib ?
You don't actually need to use the JoystickButton object, you can just use joystick.getRawButton() or joystick.getTrigger(), etc.
Otherwise, make sure you import wpilib.buttons, not just import wpilib.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 21-01-2015, 18:03
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
For some really annoying reason, I can't have an "If" statement in my code or the Driver Station will not recognize the code. I tried --nc and it shows nothing. Thanks!
Unread 21-01-2015, 18:29
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Are you typing 'If'? Make sure it's lowercase.
if xyz:
blah blah blah
And it might be helpful to put your code in pastebin and share a link so we can take a look at it.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 21-01-2015, 18:31
virtuald's Avatar
RobotPy Guy
Highly recommend using the pyfrc simulator then. It will help you find any logical issues with your code. If it runs in the simulator, it has a high chance of running on your robot.
Unread 21-01-2015, 18:59
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
With this code: http://pastebin.com/DRa0hbVy I get this error in the sim
Code:
Robot Drive... Output not updated often enough.
I don't think that would stop the code from being recognized though. Thanks!
Unread 21-01-2015, 19:46
ArchdukeTim
Rookie Year: 2011
So I ran your code and noticed that the error was wpilib.motorsafety... to fix this, under
Code:
self.robot_drive=wpilib.RobotDrive(self.motor1,self.motor2)
insert
Code:
self.robot_drive.setSafetyEnabled(False)
Also, no need for
Code:
self.teleopPeriodic()
. I think Peter Johnson mentioned this. Wpilib will call it on its own. And keep the while loop in teleop, and add
Code:
wpilib.Timer.delay(.01)
inside the loop.
Unread 21-01-2015, 23:07
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
Code:
insert
Code:
Also, no need for
Code:
Code:
inside the loop.
So that would be why the Driver Station rejects the code? Thanks a bunch and I will try that tomorrow!!
Unread 22-01-2015, 01:28
virtuald's Avatar
RobotPy Guy
When you say 'rejects the code', what do you mean? Is there an error message, or some other indicator that is telling you this?
Unread 22-01-2015, 09:15
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
The Robot code indicator is red on the Driver Station and there is no errors that show up.
Unread 22-01-2015, 09:31
ArchdukeTim
Rookie Year: 2011
So that's not the driver station rejecting the code, its the code on the robot breaking. Adding the safety code line should prevent this, and to test just run it in the simulator
Unread 22-01-2015, 11:38
virtuald's Avatar
RobotPy Guy
No, do NOT disable the motor safety error. In previous years, the motor safety stuff didn't always work as well as we would have liked previously, but this year it should work without any problems. If one is getting the motor safety error, that means that you aren't feeding the motors often enough.
Looking at the code which was pasted the robot drive motor call is commented out, so it's not feeding it at all -- which means the error message is correct. Once you uncomment it out, the error message goes away.
Additionally, since the OP is using IterativeRobot, no Timer.delay call is required.
I modified your code slightly, and http://pastebin.com/CLDhyuc5 works for me without any problems in the simulator. You'll note that I changed 'aracadeDrive' to 'arcadeDrive', which could be what caused your robot to crash. I don't have access to a robot to run it on.
Also, you don't need the from __future__ import division at the top, that is only needed for python 2.
