Go to Post A mentor, by definition, provides a nuturing environment and, over time, makes themselves progressively unnecessary. - Rich Kressly [more]
Unread 21-01-2015, 18:40
ShaneWong ShaneWong is offline
ShaneWong is an unknown quantity at this point
Question about joystick ports
Hi, I'm a programmer with team 4732. I have a question about ports. How do you figure out what port your joystick is connected to and what the buttons are mapped as? (I'm using a wired XBox controller if it makes a difference).
Unread 21-01-2015, 18:41
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Question about joystick ports
Take a look at the USB tab of the driver station.
Unread 21-01-2015, 20:31
Okay thanks. One more thing, I see that the joystick axes and triggers are labeled with numbers, how do I get the numbers for the other buttons? Do the numbers correspond with the squares that light up when I press them?
Unread 21-01-2015, 22:10
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
I believe the numbers correspond with the squares if using Java. If using C++, they're one higher than the console. Not sure about LabView.
Unread 21-01-2015, 22:14
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
Rookie Year: 2012
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
You can also go to "set up USB game controllers" in Windows to see the button numbers and calibrate the joysticks.
Unread 21-01-2015, 22:20
Nunez4296's Avatar
Nunez4296 Nunez4296 is offline
Programmer
AKA: Joseph Nuņez
FRC #4296 (Trident Robotics)
Rookie Year: 2013
Nunez4296 is an unknown quantity at this point
With the new driver station, any time you plug in a controller, it will default to port 0, and then so on. Next, go to the "USB" section on the driver station. There you will see any connected controllers as well as all the axis and buttons associated with that controller. These buttons are held in an array (in lab view that is) so the first button on the screen (the leftmost top button) will be button zero, the next one down will be button one and so on. As far as Axis, they should be labeled from 1-X straight down. Correct me if I'm wrong, but this is how my team does it.
The Eagle - By Alfred, Lord Tennyson
He clasps the crag with crooked hands;
Close to the sun in lonely lands,
Ring'd with the azure world, he stands.
The wrinkled sea beneath him crawls;
He watches from his mountain walls,
And like a thunderbolt he falls.
