Go to Post Now let's get back onto the original topic! :) - Calvin Hartley [more]
Unread 22-01-2015, 11:23
The_Waffleing's Avatar
The_Waffleing The_Waffleing is offline
The Horse Shaman
AKA: Mitchel
FRC #0753 (The High Desert Droids)
Rookie Year: 2012
The_Waffleing is an unknown quantity at this point
Exponential Motor Acceleration
I'm trying to create a motor control that will accelerate and decelerate exponentially and of course I can solve that mathematically but am having troubles in taking that idea and inputting it into Labview. I can do it in just about any other text based language but I can't seem to figure it out in Labview. Any thoughts?
Unread 22-01-2015, 12:57
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Exponential Motor Acceleration
What does "accelerate and decelerate exponentially" mean? I know what the individual words mean, but putting them together like that makes me imagine a wheel turning faster at an ever-increasing rate, quickly reaching the point of rapid catastrophic disassembly.
If you can write what you want in a C-like language, I can show you how to translate that to LabVIEW. It could even be as easy as writing it verbatim in a formula node.
Last edited by Alan Anderson : 22-01-2015 at 13:31. Reason: darn autocorrect -- I mean, corrected a mistyped word
Unread 22-01-2015, 13:18
If what you are looking for are functions for log and exp, they are in Mathematics >> Elementary Functions, right next to trig and hyperbolic. As Alan said, many of these are supported in the formula node too, using a C subset syntax.
Greg McKaskle
Unread 22-01-2015, 13:33
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Perhaps you are referring to contouring the joystick output exponentially?
Here is a joystick exponential mapping function which maps a Joystick value between 0 and +1, inclusive, to an adjusted value in the same range:
Joystick_adjusted = (1-bJoystick)/(1-b);
For range -1 to 0, use this:
Joystick_adjusted = -(1-b-Joystick)/(1-b);
b≠1 is a tuning parameter.
Example graph below with b=10
Unread 22-01-2015, 14:06
The Horse Shaman
AKA: Mitchel
Rookie Year: 2012
I chuckled with your ending bit there. What I'm trying to get at is if you fully throttle the joysticks forward instead of a sudden increase from 0 to 1 in a fraction of a second have it gradually increase over the course of 2 seconds or something of that nature. Ether I believe has answered my question however I haven't tried it yet so I will report back later if it's right.
Unread 22-01-2015, 14:16
Ether's Avatar
Rookie Year: 1969
What I posted is a joystick mapping; it won't do what you just described above.
What you want is some sort of rate limiter.
http://thinktank.wpi.edu/article/140 (look for the section titled Slew Rate – How do I limit the rate of change?)
http://www.chiefdelphi.com/forums/sh...23&postcount=2
Unread 22-01-2015, 14:36
Software Architect
What you want is called "rate limiting". Searching with that keyword phrase will give you lots of useful information. Here is one document that ought to help.
Unread 22-01-2015, 15:25
The Horse Shaman
AKA: Mitchel
Rookie Year: 2012
Talking Re: Exponential Motor Acceleration
Okay got it figured out now. Thanks a bunch for the input.
