Go to Post do i even have to say anything about hurricane jeanne after my comments about charley, frances and ivan? :mad: but if i could, i would run all of them over with my robot... - Arefin Bari [more]
Unread 22-01-2015, 20:37
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
SMC versus Bimba
Are there any advantages to using Bimba over SMC or vice versa?
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 22-01-2015, 21:30
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: SMC versus Bimba
Having only Bimba and Parker cylinders to compare, I've never noticed a difference. One advantage: you can get 2 free cylinders from Bimba.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 22-01-2015, 22:13
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
FRC 4607 CIS has used a couple of different cylinders - and Bimba has never let us down.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 22-01-2015, 23:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Both SMC & Bimba make quality products. Bimba is big supporter of First.
If you don't know what you should hook up then you should read a data sheet
Unread 23-01-2015, 01:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Ditto for 3946 Tiger Robotics.
Unread 23-01-2015, 02:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
SMC parts used to be illegal (for reasons that ranged from uncertain to bad). As a result, other teams tend to be a lot more familiar with the Bimba equivalents, and may be more likely to carry them as spares. But many cylinders are standard and interchangeable.
The product lines have substantial overlap, but you'll find that SMC in particular makes a lot of very heavy industrial cylinders that Bimba doesn't. But you probably don't want those anyway.
Basically, read the manuals thoroughly to familiarize yourself with what's available, and make your selection based on features, cost and availability rather than reputation. Both will likely be fine.
http://www.bimba.com/Products-and-Cad/Actuators/
http://www.smcusa.com/top-navigation...cylinders.aspx
