Go to Post I just like that PVC is the most basic need of humankind according to that diagram. Whatever would we do without it?! - Po-ser [more]
Unread 01-22-2015, 10:46 PM
BananaKing1378's Avatar
BananaKing1378 BananaKing1378 is offline
BaNaNaK1Ng8o8
AKA: Banene
FRC #1378 (Hilo Banana Robotics)
Team Role: Human Player
BananaKing1378 is an unknown quantity at this point
Double Solenoid error in Eclipse
Hello! We are currently trying to set up a double acting solenoid in Eclipse.
First we create a DoubleSolenoid called Solenoid with the following line:
DoubleSolenoid Solenoid;
Next we construct it:
Solenoid(0,1);
Next, we try to set the Solenoid to forward. This is where the problem occurs. We are told that there is no member named "Forward". We have tried various ways of calling "set". Currently, we are using:
Solenoid.Set(DoubleSolenoid::kForward);
Unread 01-22-2015, 11:08 PM
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Double Solenoid error in Eclipse
Solenoid(0,1);
Sounds like you're using C++, since :: is not part of java.
Doing a bit of googling, I found that kForward is actually a member of the class "Value" defined within DoubleSolenoid. I have never written any c++, but as I read the docs online, my best guess at this line would be:
Solenoid.Set(DoubleSolenoid::Value.kForward);
Unread 01-23-2015, 11:25 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Just a thought -- is the name "Solenoid" conflicting with a library class name? Pick something a little more descriptive, like "gearselect" or "toteflipper" and see if the error remains.
Unread 01-25-2015, 05:33 PM
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Close, "Value." isn't necessary, the correct parameter value would be:
Keep in mind that if you should be able to type DoubleSolenoid, the two colons and pause, Elipse should list members of DoubleSolenoid for you. I believe the constants appear near the end.
Last edited by JefferMC : 01-25-2015 at 05:33 PM. Reason: remove a period that may cause confusion.
Unread 01-28-2015, 01:26 AM
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
I'm voting with Alan on this one - change the name of your 'variable' Solenoid to something else. Both of those names are class names. That could be problematic.
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
