Go to Post If you ever find yourself thinking that you are the most brilliant person in a situation, you are doing something wrong. - EricVanWyk [more]
  #16   Spotlight this post!
Unread 31-01-2015, 13:21
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: RoboRIO Red Power LED
And for those who are curious, the returned units end up on my desk where we take them apart to see what is going on.
  #17   Spotlight this post!
Unread 07-02-2015, 12:49
diverson diverson is offline
FRC #4499 (The Highlanders)
diverson is an unknown quantity at this point
Cool, if you get a roboRIO with a shorted 5V bus in the next week or two, I'd love to know what caused the problem when you figure it out!
  #18   Spotlight this post!
Unread 14-02-2015, 11:53
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
Rookie Year: 2011
jdh042397 is an unknown quantity at this point
I may have a solution to your problem. We had the same issue with the solid red power light. We went through and unplugged all the fuses except the ones to the vrm. That wasnt the problem. So we went one by one on the PWM's and discovered that on one of them, some knucklehead switched the red and black wires on it so that the negative was in the middle instead of the positive. I unplugged it and swapped the wires back to normal and it worked.
Hope this helps.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
  #19   Spotlight this post!
Unread 18-02-2015, 17:53
AKA: Chris Rake
no team (Athena)
I found a shorted 5V roboRIO today and knocked on it really hard and the short went away. When I opened the roboRIO a thin copper wire was peeking out from under DIO 9. This wire had apparently found its way under the 3 pin header and shorted 5V to GND. Once I pulled the wire out the problem went away and roboRIO was happy again.
The controller has conformal coating so things that can be permanently damaged are protected from swarf (or random wires), but IO pins are exposed and while no lasting damage occurs, there can be a short condition that requires a little cleaning to clear up.... or a violent hit, especially if your robot's name is "tippy".
  #20   Spotlight this post!
Unread 22-02-2015, 19:13
We're not "tippy", but it is possible that something lodged under one of the IO pins that we couldn't find. If you come across one that's set for team 4499, that's the one we messed up.
  #21   Spotlight this post!
Unread 22-02-2015, 19:16
Hope this helps.
I appreciate the tip. We're not using PWMs, unfortunately. So that's not the problem we had, but I'm glad you were able to successfully debug your problem. Nice detective work!
  #22   Spotlight this post!
Unread 22-02-2015, 21:23
AKA: Chris Rake
no team (Athena)
On Friday I performed an IR scan on this unit and found the over current protection engaged (expected for a 5V short) but no other hot spots. Compressed air under the AI/Relay IO connectors seemed to have cleared the fault. I suspect that the air dislodged whatever was causing the short condition though I never did see what was shorting it.
  #23   Spotlight this post!
Unread 11-03-2015, 08:53
Thank you! I'll add the compressed air treatment under the connectors to our list of troubleshooting steps. We blew off the board in general, but obviously not well enough! I really appreciate you taking the time to let us know.
Dean
  #24   Spotlight this post!
Unread 11-03-2015, 10:41
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
Rookie Year: 2012
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Quick side note: make sure the fuses on your RoboRIO are in all the way and properly secured. Our fuse kept on getting knocked out of place, causing the RoboRIO to reboot during matches.
  #25   Spotlight this post!
Unread 11-03-2015, 19:21
Anthony4939 Anthony4939 is offline
None #4939
Anthony4939 is an unknown quantity at this point
We had this problem......caused all kinds of connections issues.
We took it apart and found a few metal shavings. Havn't been able to test it yet.
We ordered a second just to be safe.
