Go to Post I love FIRST because it makes the dreams of tomorrow seem so much closer. - WakeZero [more]
Unread 23-01-2015, 15:34
TheMechanic40 TheMechanic40 is offline
FRC #3506 (YETI Robotics)
Rookie Year: 2013
TheMechanic40 is an unknown quantity at this point
Can you get joystick values?
Hello everyone, does anyone know if there is someway to get what button is currently being pressed on a joystick? Let provide some context: My team, 3506, is using a command based robot and we've just created a way to record the values taken from the joysticks and save them to a file so they can be used as the autonomous. We know how to record the various button inputs and the joystick axes values and we can do this successfully, but in order to be able to detect the button presses and save them we have to edit three different classes. So my question is: Is there a way to detect any button on a joystick and return a which button is being pressed?
Unread 23-01-2015, 16:44
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Re: Can you get joystick values?
In either java or c++, they're both very similar.
Check out the getRawButton method in the joystick class
http://wpilib.screenstepslive.com/s/...1881-joysticks
[edit]
If you're asking how to get the status of all buttons simultaneously, look at the getStickButtons method in the DriverStation class.
Source code is here:
http://team2168.org/javadoc/src-html....html#line.291
Not really sure what the format of the returned in it. I would assume it's that each bit is set corresponding to button id. The code isn't really commented... so you'll need to just try it out and see.
http://team2168.org
Unread 23-01-2015, 17:47
Quantum Byte's Avatar
Quantum Byte Quantum Byte is offline
Lead Programmer
AKA: Domenic
FRC #4776 (S.C.O.T.S. Bots)
Rookie Year: 2011
Quantum Byte is an unknown quantity at this point
Check out our GamePad util class (Java) for our robot. It makes joystick mapping easy!
https://github.com/SCOTS-Bots/FRC-20...s/Gamepad.java
Unread 24-01-2015, 13:59
Rookie Year: 2013
[edit]
Thank you so much this worked perfectly.
