Go to Post You know you've made it big when people assume every imperfection is genius! - araniaraniratul [more]
Unread 24-01-2015, 11:09
BLUEBELL BLUEBELL is offline
FRC #3773
BLUEBELL is an unknown quantity at this point
FRC plugin help
I installed the FRC plugins in Eclipse Luna on Debian Wheezy, but I am unable to create a WPI robot project. The only error I am given is
Code:
org.osgi.framework.BundleException: Could not resolve module: edu.wpi.first.wpilib.plugins.core [425]
  Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.7))"
	at org.eclipse.osgi.container.Module.start(Module.java:434)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Could anyone shed some light on this issue?
Unread 24-01-2015, 11:24
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
What version of Java are you running?
Unread 24-01-2015, 11:36
FRC #3773
Re: FRC plugin help
We are using Java SE Development Kit 8
Unread 24-01-2015, 13:42
Rookie Year: 1997
Re: FRC plugin help
I suspect eclipse is using debians default version of java (OpenJDK 6, if I remember correctly), not the the JDK you installed. You can check in the eclipse installation details.
Unread 02-02-2015, 18:31
FRC #3773
Re: FRC plugin help
Now I can create programs but I cannot deploy them to the roboRIO. I have deployed successfully to the roboRIO on Windows, but when I try to deploy in Linux it says BUIILD SUCCESSFUL but the driver station says "No Robot Code"
Unread 02-02-2015, 18:34
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: FRC plugin help
That probably means that your code is crashing. Look in Riolog or the DS log for any messages.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
