Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
Unread 01-24-2015, 12:12 PM
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Another DoubleSolenoid question
We're constructing our DoubleSolenoid as follows in RobotMap.cpp
pneumaticSubsystemSolenoid = new DoubleSolenoid(11, 0, 1);
The '11' is the CAN ID of the PCM. With these parameters, our compressor starts automatically as expected. However, we're getting the following error:
Error on line 87 of Resource.cpp: Allocating channel that is out of range: Solenoid 0 (Module: 11)
When we change the '11' to a '1', this error goes away, but our compressor doesn't start.
Any thoughts?
Unread 01-24-2015, 02:51 PM
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Another DoubleSolenoid question
Hmm it looks like that assert will trip on anything >= PCM Device ID 8....
const uint32_t solenoid_kNumDO7_0Elements = 8;
...HAL.cpp in wpilib. This gets passed into a Resource object which trips on line 87 of Resource.cpp.
Not sure if that's the intent of the code's author, but I would keep the device ID less than '8' just to be safe. Hopefully you have less than 8 PCMs!
The reason changing the param in your c'tor to '1' from '11' breaks the compressor is likely because you didn't change the PCM ID to '1' in the RIO web-page config.
Setting the device ID...
http://wpilib.screenstepslive.com/s/...ribution-panel
Unread 01-24-2015, 08:14 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Why have you changed your PCM from the default ID of 0?
