Go to Post w0000000000000t! - Andy Baker [more]
Unread 24-01-2015, 12:32
WawerOS WawerOS is offline
FRC #4215
WawerOS is an unknown quantity at this point
Max Voltage for Analog Inputs
How will Voltage equal to and beyond the maximum allowed input for the Analog input affect the Roborio, how will it damage the the ports, are the ports recoverable. How will these scale with increased voltage, 5.5 V, 6V, 8V, 10V. Any help is appreciated.
Unread 24-01-2015, 18:59
Dexterium's Avatar
Dexterium Dexterium is offline
AKA: Adam Poindexter
FRC #1208 (Metool Brigade)
Rookie Year: 2011
Dexterium is an unknown quantity at this point
Re: Max Voltage for Analog Inputs
Is there a specific reason you wish to overpower the input? The general answer, regardless of end result, would be, "No! Bad! Don't do that."
If your sensor has a large output you can, and probably should, scale that input down to the standard levels.
Unread 24-01-2015, 21:50
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The RoboRIO Specifications document quotes overvoltage protection of ±16 volts on the Analog Inputs.
I found that document by going to http://ni.com/FIRST and following the FIRST Robotics Competition link, then clicking the NI roboRIO link near the top of the page.
Unread 27-01-2015, 07:09
FRC #4215
Thanks for all the help!
