Go to Post Dedication to FIRST gets more challenging as life gets more complicated but the rewards are SOOOOO worth it! - Sean Schuff [more]
Unread 24-01-2015, 13:02
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Vex Ultrasonic Range Sensor (WPILib)
At 6:33 in this video, the instructor mentions that there is WPILib support for decoding the signal from the Vex Ultrasonic Range sensor mentioned at 4:17 in the video.
Can someone familiar with the relevant WPILib code please clarify how the time to receive the reflected ping is determined? Specifically, is a hardware interrupt set up to detect the reflected ping? If so, does the ISR for that interrupt do the timestamping, or does the ISR just set a flag alert the scheduler to run a task which does the timestamping? Or is the reflected signal detected by polling, and if so, what is the polling frequency and priority?
Unread 24-01-2015, 13:09
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Vex Ultrasonic Range Sensor (WPILib)
It sets up a counter fpga object in semi-period mode.
Unread 24-01-2015, 13:17
Ether's Avatar
Rookie Year: 1969
Thanks Joe. So it would be polled at 1MHz* by FPGA?
*polling frequency increased from 153KHz (2014) to 1MHz (2015)?
Unread 24-01-2015, 16:45
Rookie Year: 1997
Yes
