Go to Post As a wise man from PA once said to me "Changing the culture is hard work." - RoboMom [more]
Unread 24-01-2015, 16:21
JByland's Avatar
JByland JByland is offline
AKA: Journey
FRC #1712 (DAWGMA)
Rookie Year: 2013
JByland is an unknown quantity at this point
Rightsight Optical Sensor Help
Hello all- we using an optical sensor called a rightsight made by Allen-Bradley on our robot this year, but don't really know how it works or how to program it. Does anyone have any information on this?
Unread 24-01-2015, 17:58
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Rightsight Optical Sensor Help
What are you trying to use them for?
From what I can remember they were given in the 2011 KOP to track lines on the field. I think they output a digital signal depending on whether they detect a dark object in front of them. See this thread for wiring information.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 24-01-2015, 21:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That sensor has four wires, with colors Brown, Blue, Black, and White. Brown needs to be connected to 12 volts and Blue goes to "ground"/common. A VRM output would probably be appropriate. Black and White are essentially switches to ground, only one of which is active at a time. Black activates when the sensor is not seeing an object; White activates when it is. Only one of them is necessary, and should be connected to the SIGnal pin of a Digital Input port.
It is a light source and light detector pointing in the same direction. It senses when something is in front of it and reflecting the light.
