Pneumatics Wiring
I'm surprised that the compressor is connected directly to the PCM. See http://wpilib.screenstepslive.com/s/...he-2015-system.
Past (2014 etc), the wiring requirements included the PDB with a circuit breaker and a relay (which included a fuse). Strikes me as odd. How do we not need to same safety and isolation features? Seems like we could still wire the compressor the old way, but why aren't we required to wire through the PDP? Thoughts? Comments? |
Re: Pneumatics Wiring
Thank you! I hadn't worked back that far with the wiring to notice the additional protection.
That makes me feel better. ![]() |
The PCM also has some fancy circuitry that's able to detect shorts/other faults and shut down the compressor way faster than a fuse/breaker.
It also has an automatic shut-down to the compressor if the limit switch ever becomes disconnected or unresponsive.
Can we wir the Old Festo Solenoids
Though it only takes 12V inputs, it does have a jumper to switch to 24V output. Was this your concern?
More detail on this at: http://khengineering.github.io/RoboRio/faq/pcm/ Last edited by GeeTwo : 03-02-2015 at 17:13. Reason: add link |
Thanks I found this
Single Solenoid came in previous Kits and is marked as model # VPLE18-M5H-4/2-1/4 Festo Solenoid Valve Assembly (Adobe PDF, 41 KB) http://www.team358.org/files/pneumatic/ On some of these special order valves the wiring does not follow the standard directions (use terminals 1 & 2). If your valve doesn't work when power is applied, then switch your positive wire from terminal 2 to terminal 3 (use terminals 1 & 3). |
