Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 24-01-2015, 20:35
hems4321 hems4321 is offline
FRC #5624
hems4321 is an unknown quantity at this point
4 inch omni's
I'm wondering if any 4 inch omni woud be able to clear the scoring platform. We ordered 4 inch dualies from andymark with the assumption that they would not get stuck. If any team has experimented with 4 inch omnis, please reply if they've worked or not.
Unread 24-01-2015, 20:52
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: 4 inch omni's
Not if you put four of them onto a KOP chassis and make the center wheel into a spacer - there just isn't enough ground clearance over the WCD-mounted gearbox. (We're going this this year, so I've worked this one out.)
If your chassis has enough clearance-to-length ratio at the nose to clear the 16 degree ramp on approach, and more than about 1" of clearance around the center, and you haven't geared too high or used slick omni wheels, you should be able to manage it.
Unread 25-01-2015, 10:47
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: 4 inch omni's
Do a quick sketch in cad. Its possible but not trivial.
Mentor 2415
Unread 25-01-2015, 11:54
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Re: 4 inch omni's
Yesterday we had Greenhorn ' s robot at our business expo and it had little to no problem getting over the scoring problem. It has 4" omnis and a 6" AM omni on the slide.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 25-01-2015, 14:09
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
FRC #0973 (Greybots)
Rookie Year: 2012
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Re: 4 inch omni's
We tested this with a custom chassis from last year, definitely agree with GeeTwo; gearbox height is the biggest issue.
In the future, it would be good to test the design in CAD or on a piece of paper before you buy. That could have been an expensive mistake.
(2015-?): 973
(2012-2015): 955
Unread 29-01-2015, 01:13
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
Rookie Year: 2011
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Re: 4 inch omni's
We put VexPro 4" omnis on our drive base, which has the wheels mounted at 45 degrees in each corner, in gearboxes that are mounted 1" below the chassis. It clears the platform just fine.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 29-01-2015, 08:12
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: 4 inch omni's
Depends on the drive train setup. We've put a pair of 4" duraomnis on the front of our 6WD and have had no problems whatsoever. I was personally surprised at how well they've worked; I was expecting them to slide sideways on the slick ramp. However, we've found that the grippy kit wheels in the middle and back keep the robot steady.
Our chassis is just under 28" long.
However, I would not expect the same results with a 42" long 4WD system.
Hi!
