Go to Post resistance to FIRST is futile. - King Duke [more]
Unread 25-01-2015, 10:36
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Updated information for using SPI on the RoboRio
I'm looking at using SPI on the RoboRio.
I used it in 2012 on the CRIO, but as I look at the LabVIEW VI's there are obvious changes.
Unfortunately the "Detailed Help" still refers back to all the old 2013 VIs.
Some things I'm trying to figure out:
If I select the MXP interface, which pins are used for Clk and Data.
What are the Internal interfaces listed?
I get to select the Clock Rate. What is a reasonable Max for this input.
Any other peculiarities I should know?
Is there updated docs anywhere?
Thanks in advance.
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
