I've been trying to deploy the code to our test bot, but I keep getting am error message everytime and after searching around for quite awhile I haven't really gotten any closer to finding out what's wrong so I was hoping someone here could help.
Error Message:
Unhandled exception instantiating robot org.usfirst.frc.team3655.robot.Robot java.lang.ExceptionInInitializerError at [java.lang.Class.forName0(Native Method), java.lang.Class.forName(Class.java:259), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:197)]
Robot class Code
Code:
package org.usfirst.frc.team3655.robot;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import org.usfirst.frc.team3655.robot.commands.*;
import org.usfirst.frc.team3655.robot.subsystems.*;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class Robot extends IterativeRobot
//Update EVERYtime you make a change to make sure you deployed the correct version!!
public static final String VERSION = "0.0.04";
//SubSystem Variables
public static final Elevator elevator = new Elevator();
public static final Gyroscope gyro = new Gyroscope();
public static final MecanumDrive mecanumDrive = new MecanumDrive();
public static final RotaryEncoder encoder = new RotaryEncoder();
public static OI oi = new OI();
//Commands
Command teleOpDrive;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit()
System.out.println("Robot Init v: " + VERSION);
oi = new OI();
// instantiate the command used for the autonomous period
teleOpDrive = new TeleOpDrive();
public void disabledPeriodic()
Scheduler.getInstance().run();
public void autonomousInit()
* This function is called periodically during autonomous
public void autonomousPeriodic()
public void teleopInit()
//Starts TeleOP drive base
if (teleOpDrive != null) {
teleOpDrive.start();
* This function is called when the disabled button is hit.
* You can use it to reset subsystems before shutting down.
public void disabledInit()
//Kills the drive base for teleOP
teleOpDrive.cancel();
* This function is called periodically during operator control
public void teleopPeriodic()
//Runs the button checking, probably not the best way but it'll work for now.
oi.teleOpJoyStick();
* This function is called periodically during test mode
public void testPeriodic()
LiveWindow.run();
*I set up most of the command groups to be ran from the OI when a button is pushed if that's helpful as well. Thank you for any help in advance.
