Go to Post Screws come even smaller, #0000 - 160 at Small Parts.They're about $4 each, and made by elves. - DonRotolo [more]
Unread 01-25-2015, 04:16 PM
PredaFran PredaFran is offline
Amateur Programmer
AKA: Francisco
FRC #5285 (Sea Kings Robotics)
Rookie Year: 2015
PredaFran is an unknown quantity at this point
Question Help with Swerve Drive
As a C++ programmer, this is my first year programming with motors,encoders,the roboRio,etc. and my Team has been developing a swerve drive off-season,and my experience is not helping me with it, so i have been doing a lot of research about it, looking for templates,basics but i still cant manage to do it, so i came here to ask help, suggestions, tips. Everything that can help me
Info about the swerve drive: (attached an image)
*4 motors will be linked using chains, in groups, left(upper and lower) and right(upper and lower)
* it will only be able to rotate 180° to the lafet and 180° to the right
* we are still deciding if we are going to use the CANTalons or Victors
All suggestion are accepte
Thanks
Unread 01-25-2015, 04:32 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Help with Swerve Drive
swerve has at least 8 motors (4 steering + 4 propulsion). which set of 4 are you referring to above?
Unread 01-25-2015, 04:33 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Sorry, 4 motors in the wheels, and 2 that move the chains that steer
Unread 01-25-2015, 04:36 PM
Ether's Avatar
Rookie Year: 1969
So, you have independent control of the wheel speed for each of the 4 wheels, but the front and back wheels on each side are chained together for steering?
Unread 01-25-2015, 04:37 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Yeah
Unread 01-25-2015, 04:41 PM
Ether's Avatar
Rookie Year: 1969
Yeah
when you steer the front right wheel to the right, does the rear right wheel steer to the right also, or to the left?
Unread 01-25-2015, 04:45 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
to the right too
Unread 01-25-2015, 04:53 PM
Ether's Avatar
Rookie Year: 1969
to the right too
What kind of driver interface do you have in mind?
Unread 01-25-2015, 04:57 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
Smartdashboard
Unread 01-25-2015, 05:06 PM
Ether's Avatar
Rookie Year: 1969
Smartdashboard
Configured how? What is the interface presented to the driver?
Unread 01-25-2015, 05:08 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
wait, sorry for that, we are going to use the FRC driver station
Unread 01-25-2015, 05:12 PM
Ether's Avatar
Rookie Year: 1969
So, no joysticks. No Xbox controller. Just the FRC Driver station?
Unread 01-25-2015, 05:17 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
ohh, didnt get that, we are going to use the 3d extreme pro joystick for the driver, because its 3-axis
Unread 01-25-2015, 05:19 PM
Ether's Avatar
Rookie Year: 1969
ohh, didnt gert that, we are going to use the 3d extreme pro joystick for the driver, because its 3-axis
What does your drive team want each axis to do?
  #15   Spotlight this post!
Unread 01-25-2015, 05:23 PM
Amateur Programmer
AKA: Francisco
Rookie Year: 2015
X-Axis: left, right
Y-Axis: fowards and backwards
y-rotate: rotate in the place and while moving
By the way, thanks a lot for the help so far, we really appreciate it
