Go to Post At every event I've seen this year, there has been at least one robot that left a part on the field. Even some of the robots have decided they don't want to play and this year and made a break for it in autonomous! :yikes: - ctt956 [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 25-01-2015, 20:34
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
How thick to buy HDPE?
Hi all - question for those of you who have already experimented with HDPE:
We have built a practice (half) field from plywood. We'd like to upgrade portions of the step, platforms, and chute to have HDPE surfaces (we don't have the cash to do it all). I'm wondering what's the thinnest sheet of HDPE we can get away with (assuming we glue it down), without having to worry about it tearing or bunching. 6 mil (vapour barrier)? 1/32"? 1/16"? (available from McMaster Carr), thicker?
Unread 25-01-2015, 20:50
BlueOps4216MrG's Avatar
BlueOps4216MrG BlueOps4216MrG is offline
Coach
FRC #4216 (Blue Ops)
Team Role: Coach
Rookie Year: 2012
BlueOps4216MrG is an unknown quantity at this point
Re: How thick to buy HDPE?
We used 1/8" on the Tote Chute and 1/4" on the scoring platform , you could probably get away with 1/8" over plywood on the scoring platform. Find an industrial plastics dealer and see if they will donate "cutoffs".
Unread 25-01-2015, 20:52
Jean Tenca's Avatar
Jean Tenca Jean Tenca is offline
Head Mentor
AKA: "John"
FRC #4488 (Shockwave)
Jean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of light
The problem that our team ran into when buying HDPE for the field elements was finding the correct finish. The chute uses a 'smooth' finish while the ramp and step use a 'orange-peel' texture. There is a significant friction difference between the two. Due to the texture, I wouldn't recommend going thinner than 1/16". However, I think your limiting factor will be what size you can find with the 'orange-peel' finish (We have tons of local plastics suppliers but only one had 'orange-peel' and only in 1/4" sheets). I'm not sure what McMaster has, though I'd guess it's standard 'smooth' finish. Good luck!
Team 4488 Head Mentor
2015: [Carson Division Finalists (World Championship)], [Finalists, Entrepreneurship Award (PNW District Championship)], [Winners, GP Award (CWU District)], [Winners, Engineering Excellence (Oregon City District)]
2014: [Galileo Division Finalists (World Championship)], [Finalists, Quality Award (PNW District Championship)], [Winners, Industrial Design (Wilsonville District)], [Winners, Chairman's (Oregon City District)]
2013: [Rookie All-Star (Curie Division)], [Highest Rookie Seed, Rookie All Star (Autodesk Oregon Regional)]
2006-2012: Mentored various teams in OR and WA
2005: Team 1510 captain, founding member
2002-2004: Team 955 student/captain, founding member
Unread 25-01-2015, 22:17
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Orange peel is the same as textured or cutting board. Probably more difference in the different manufactures. It is a commodity item. So says my plastics supplier. Problably get away with 1/8 screwed to plywood on the top. I would be wary of less than 1/4 on the side. One 4x8 sheet will give you enough to give you a feel
If you don't know what you should hook up then you should read a data sheet
Unread 26-01-2015, 07:32
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
Rookie Year: 2010
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
To get the 'orange peel' texture, look for Starboard. It will have the correct finish. Most unbranded HDPE will have the smooth finish. For the chute, 1/16 inch sheets should be fine as a surface. Going thinner for the Step could prove difficult just because thin Starboard is hard to find.
Unread 26-01-2015, 09:55
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Is "Starboard" a manufacture or brand name? Is it what First specifically used on the field? Agreed that unless you specify a surface finish you are likely to get smooth.
Unread 26-01-2015, 11:04
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
Rookie Year: 2010
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Starboard is name for the "orange peel" plastic.
See the "marine sheets" on this page http://www.mcmaster.com/pdf/121/3634.pdf of the McMaster catalog. The regular sheets are presumably the smooth finish.
--Jacob
Illinois FTC FTA
Unread 26-01-2015, 12:09
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
StarBoard is a brand name. http://www.tapplastics.com/product/p..._starboard/526
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 26-01-2015, 16:56
DonRotolo's Avatar
Back to humble
FRC #0832
I have seen the official FRC HDPE material that is used on the fields, it is (as already said) orange peel finish, about 3/16" thick.
We have decided to use the "regolith" plastic we still had hanging around from Lunacy, which was polyester sheeting used for shower stalls and the like, again with a bumpy finish. It *seems* like it is a good facsimile for the official HDPE.
