Go to Post Our opponents didn't know where our robot was going and neither did we! - ReapersRule [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 25-01-2015, 20:47
roialex's Avatar
roialex roialex is offline
FRC #5444 (Vobotik)
Rookie Year: 2015
roialex is an unknown quantity at this point
Encoder+PID = How make robot going straight
Hi,
My team and I tried to make robot going straight by using pid en the rate of our encoder on our motor (1 each side). Unfortunately it finish by not working at all. Here is our code that we tried but the robot was just spinning without any control you just needed to make the robot enable and it was spinning alone. We took the rate of our encoder divide it by 3700 wich is a theoretical value that represent the maximum rate that our motor were able to go. This should now gave us a value between 0 and 1. We took this value and make it the process variable in our PID. We too also the variable fromm our joystick wich range between -1 and 1 and make it our setpoint in the PID. We took the output of the pid and set it to the motor. Brief it doesn't works maybe we are not doing it right. Our goal is just to make our robot going straight how to do it ? Do you have any advice on how make you robot going straght with encoder or how improve our code ?
Thanks in advance,
Alex Rousseau
Student programmer
VObotik team 5444
Unread 25-01-2015, 20:52
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Encoder+PID = How make robot going straight
We find it soooo much easier to make a robot go straight with a GYRO verses encoders. So if your application or goal is to go straight maybe try with a gyro if you have one?
Here is some pseudo code in excel with a simple "P" loop that works for autonomous mode.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 25-01-2015, 22:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If your goal is to make the robot go straight, and you're using Arcade drive, then it is probably easiest to put the closed-loop control on the turn input rather than on the individual motor outputs. You can either use a gyro as Chris suggests, or use the difference of the left and right encoders to tell you how much the robot thinks it has turned.
