Go to Post Maybe its time we should all get back to the basics...the joy of building something amazing with the people you care about. - Andy Grady [more]
Unread 26-01-2015, 16:35
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
Team Role: Teacher
Rookie Year: 1999
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Do CIM elevator motors overheat?
We tested the CIM coolers last year and found that while they had a small (but consistent and statistically significant) effect in keeping the motor from heating up too much (on the order of 5%), they aided quite a bit in cool down time. Particularly if a fan was included. I wish our design had been better and we had included them on the final drive train. I have a friend who design motors for a living who explained that while most of the heat is dissipated through the shaft for a motor like this, the case obviously heats up so it is dissipating non-trivial amounts heat through the case. And that if you are operating the motor in a way that causes it to heat up excessively, you should try to redesign. But if that isn't possible even small amounts of increases heat dissipation can have a positive impact on motor performance and longevity.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 26-01-2015, 16:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
One concern I would have with a stalled motor is the effect on the commutator. With the shaft even rotating slowly you are spreading the current over all the segments rather than the 2 the brushes are on with a stalled motor. Other that that--what Adam said.
If you don't know what you should hook up then you should read a data sheet
Unread 26-01-2015, 18:21
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by Ether View Post
Richard Wallace has conducted and reported some excellent tests documenting this. I'll post a link later unless someone else beats me to it.
Here's one report I found:
http://www.chiefdelphi.com/forums/sh...13#post1215913
Unread 26-01-2015, 14:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by marccenter View Post
When the CIM elevator motor stops moving to hold a tote at a given height it is effectively stalled (motor speed nearly zero) and maximum current is drawn.
This doesn't sound quite right. A motor's rated stall torque is not the same as the torque required to hold a specific load in one place. If you figure out the torque required to do that with your design, then you can figure out how much current the motor will require to maintain that torque.
It might make the motor smoke...it might not.
Unread 26-01-2015, 14:27
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Dear CD,
I was wondering if any teams that have progressed further into their build so far have determined that the elevator CIM motors overheat due to stalling?
I am assuming you are using a gearmotor attached to a CIM with a gear reduction ratio in the order of 50 to perhaps 90:1.
Have you found that your CIM elevator mount overheats in a two minute match? Were you holding one, two, three, or four totes?
Have you found it necessary to add an active braking mechanism to aid in the problem?
Why use such a big reduction? Unless you are using a pulley that is about a foot in diameter, that will most likely be too much reduction, and too slow.
If an average pulley/sprocket is about 2.5 inches in diameter, a 70:1 reduction off of a CIM will have a free speed of 0.87 ft/s, and a stall force of 1200 lbs. If you had to stall a CIM to hold up 60 lbs at that reduction, you would be using 5% of your stall torque. A CIM could do that basically forever without problems.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 26-01-2015, 14:38
Ether's Avatar
Rookie Year: 1969
The current draw is only what is required to produce the torque necessary to hold the weight. This in turn depends on the gear ratio.
Here's an excellent video
explaining motor selection and gearing.
