Go to Post I was very concerned about this thread. Then I realized you were talking about a computer. - Taylor [more]
Unread 26-01-2015, 15:03
amandans amandans is offline
FRC #3659
amandans is an unknown quantity at this point
2go PC Boot menu- HELP!
I'm not sure if this is under the right forum or not. However, I am trying to load the Classmate Images onto my 2go pc but it isn't working. I put the file on an external hard drive and the pc recognizes it, but won't use the file to boot the computer.
HELP PLEASE!
Unread 26-01-2015, 16:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: 2go PC Boot menu- HELP!
The downloaded file is not something that can be used to boot a Classmate. It's an image that must be written to a USB flash drive using the RMPrep tool. See the detailed instructions:
Imaging your Classmate (Veteran/Rookie Image Download)
Unread 26-01-2015, 17:06
bjbmcd's Avatar
bjbmcd bjbmcd is offline
AKA: Brendan Burke
FRC #3974 (E=mCD)
Rookie Year: 2012
bjbmcd is an unknown quantity at this point
An alternative solution is to contact a nearby rookie team and ask to borrow the flash drive that came in their KOP. We had trouble creating a boot-able flash drive using the RMPrep process and team 5407 assisted us. Thanks Wolfpack Robotics for your GP.
Unread 27-01-2015, 22:27
agapedad agapedad is offline
FRC #5413
agapedad is an unknown quantity at this point
The USB stick that came with ours had corrupt files. Follow Alan's link and create new image file (can format and use same stick) and it will work perfect.
