Go to Post Invest our time in enhancing the process of conceiving, designing, testing and deploying the game - billylo [more]
Unread 26-01-2015, 15:54
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Programming US Digital Encoder
So I am trying to get a motor to go to a certain position using the encoder provided by US Digital, and am having trouble.
Code:
self.talon = wpilib.CANTalon(15)
        self.talon.changeControlMode(CANTalon.ControlMode.Position)
        self.talon.setFeedbackDevice(CANTalon.FeedbackDevice.EncFalling) #Not sure if the encode is EncFalling or Quad
        self.talon.reverseSensor(True)
        self.talon.setP(1)
        self.talon.setPosition(0)
and in OperatorControl
Code:
  self.talon.set(270)
But when I enable the DS, the motor just keeps spinning, and the value goes past 270.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 26-01-2015, 15:59
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: Programming US Digital Encoder
Code:
        self.talon.setP(1)
Code:
  self.talon.set(270)
You do want to be using Quad for an encoder like that.
Remember that the encoder is always in 4x mode, which means that 1 rotation of the shaft is 1440 pulses is using a 360 CPR encoder. Moving from 0 to 270 is only moving the output shaft about 80 degrees. Is that what you want?
Also, the P gain needs to be a much smaller number then 1. With a P gain of one, your motor will always be moving at a full speed. I would recommend using a P gain of 0.01, if not 0.001 to start with, then start increasing from there if its not moving fast enough, or at all.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 26-01-2015, 16:39
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Put some sort of mechanical load on the motor when you're trying out closed-loop position control. If you don't, it's going to overshoot. A lot.
Unread 26-01-2015, 17:00
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
You're sensor is not single-direction (not a tachometer). So you want to select Quad-encoder. That's part of the problem.
So you're initial closedloopErr is +270 ( target - currentPos), such that currentPos is about '0'. 270 times a pgain of '1' will yield '270'. That's about 26% positive throttle (1023 is full, see Duty-Cycle Section 17.5 in software reference manual). So I think that's ok.
Also I see that you reversed the sensor. I'm guessing you followed the procedure in section 7.4 (or similar) to ensure that positive throttle makes "Sensor Position" move in the positive direction.
Just curious how did you hookup the encoder to the motor mechanically. I mean what's the gear ratio between the two?
Unread 26-01-2015, 17:52
ArchdukeTim
Rookie Year: 2011
Can you explain how you came up with 80 degrees?
So for testing I have it hooked up to a super shifter. On the actual robot we will have it on a planetary gearbox which is 16:1 I believe
Unread 26-01-2015, 17:58
Rookie Year: 2010
One rotation of the output shaft is 1440 pulses. Thats 0.25 degrees per pulse. 0.25 * 270 pulses is 67.5 Degrees to be exact. The 80 was more a guess just by looking at the ratio, but I guess I was a little off. Its 67.5 Degrees.
Unread 26-01-2015, 18:00
ozrien's Avatar
Omar Zrien
AKA: Omar
Cool. You should be able closed loop position with that. I've tested closed-looping a quad encoder right to the output shaft of a CIM (>5000 rpm) using the S4 encoder (360 cpr) so that'll work.
My math says : 360cpr = 1440 position units per rotation.
270 / 1440 = 0.1875 rotations or 67.5 deg.
Also checkout section 11.2 for checking on the closed-loop err and the applied throttle to sanity check your closed-loop.
