Go to Post These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half." - Alex Golec [more]
Unread 26-01-2015, 19:11
silver505's Avatar
silver505 silver505 is offline
Dragon Robotics 2375
AKA: Marlen (Thing 2)
FRC #2375 (Dragon Robotics)
Team Role: Photography
Rookie Year: 2012
silver505 can only hope to improve
Cool Pivot Lever Arm
We want to pivot a lever arm. Are there any type of bearings we can use or anything similar that will pivot?
Unread 26-01-2015, 19:47
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Pivot Lever Arm
Yes, there are such items--bearings, bushings, and the like.
What exactly you use will depend on your exact problem. Is it pivoting on a live axle or a dead axle? How much force (approximately) is it carrying? Does it need to turn freely, or is some potential binding OK? Are you dealing with a large axle or a small one (diameter-wise)?
The answers to some of those questions will point to a bearing. Others may point to a bushing. Some are irrelevant. (And then there's the question of where to put the bearing or bushing or whatever else you opt to use.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 26-01-2015, 22:42
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: Pivot Lever Arm
depending on the application a simple shoulder bolt could do the job. really easy to use cheap and can find them at any hardware store.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 27-01-2015, 01:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Pivot Lever Arm
Yes, we used this last year for our pickup arm. If you do this, I recommend have the same piece at both ends of the bolt so the head and nut can rotate together with that piece. You would also do well to put teflon washers on both sides of the center "tongue". Using the clevis setups that Bimba gave you with the free cylinders you ordered is another low-cost, low frustration, option.
Unread 27-01-2015, 00:50
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Pivot Lever Arm
Bearings can support some pretty beefy loads depending on shaft size (a 3/4" bearing tends to have a high rating than a 1/8" one). I design with bushings for anything that is low-speed rotation, like arms, because they're cheap and don't need to be lubricated (in some cases).
