Go to Post Ineveitably what we do just might end up in the hands of millions of people. - JoeXIII'007 [more]
Unread 27-01-2015, 10:04
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Command Based Programming (Threads?)
Thanks for the response. I hope you don't mind some follow-up questions:
Originally Posted by notmattlythgoe View Post
I would suggest using a WaitCommand in a CommandGroup. Below is an example that will fire, then wait 1 second before firing again and then finishing the CommandGroup.
Code:
public FiringCommandGroup extends CommandGroup {
     public FiringCommandGroup() {
          addSequential(new FireCommand());
          addSeqiential(new waitCommand(1));
What does the waitCommand() do, "under the hood". i.e., how is it implemented?
Another way to do it would be to check the time passed in the execute method of a command to see if the period of time you want to wait has passed.
Is there a "recommended" or "best practice" way to implement that approach?
