Go to Post We should create string networks at Nats. Just have miles of string running between the Georgia Dome and the GWCC. :D - Ctrl Alt Delete [more]
Unread 27-01-2015, 17:20
roberthashley roberthashley is offline
FRC #2611 (Jactown Vectors)
Rookie Year: 2013
roberthashley is an unknown quantity at this point
Exclamation Gyro Drive Straight
How to you use a gyro to keep your bot driving straight. We are using LabView.
Unread 28-01-2015, 00:21
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Gyro Drive Straight
If you know what direction you want the robot to face, and you know what direction it is currently facing, you can use the difference between them to control the "turn" input of either a Mecanum or Arcade drive function.
If you scale the values properly, that will tend to rotate the robot toward the desired direction. That's a simple Proportional control system, which is what the "P" in "PID" stands for. If you find that you can't get the robot to hold its direction strongly enough without overshooting and oscillating, then you need to implement a more complete PID control with some Integral to account for the steady-state error, and perhaps some Derivative to reduce overshoot when the error starts out too high.
Unread 28-01-2015, 11:11
Rookie Year: 2013
Can you post a screenshot of that please im a visual learner.
Unread 28-01-2015, 12:35
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Rookie Year: 2011
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
I will be able to post some screenshots of the general principal of how this works later today, sometime around 4:00 CST (maybe sooner).
Unread 28-01-2015, 13:43
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
What kind of drivetrain do you have, and what software are you using to control it?
If you have a mecanum drive and are using mecanum_Cartesion, here's a picture showing an approach you could use to drive straight at any desired orientation angle.
Unread 28-01-2015, 15:21
Rookie Year: 2013
We are using Tank Drive.
Unread 28-01-2015, 16:42
Ether's Avatar
Rookie Year: 1969
Please be more specific.
"Tank Drive" means different things to different people in different contexts.
[1]What kind of drivetrain do you have1, and
[2]what software2 are you using to control it?
1details please: number and type of wheels, number of gearboxes and gear ratio, chains/belts/direct, etc etc. The more detail, the better.
2e.g. what vi are you using, and how is your driver interface (joystick) mapped to that vi's inputs e.g. arcade, tank, other?
Unread 28-01-2015, 16:55
Rookie Year: 2013
six wheel
two mini cims preside
belt
two shifting gearboxes
i don't know the gear ratio
Xbox Controller
Dose that help
Unread 28-01-2015, 17:36
Ether's Avatar
Rookie Year: 1969
six wheel
belt
Xbox Controller
Dose that help
Somewhat.
What does "two mini cims preside" mean?
Also can you get answers for the questions highlighted in red below:
Unread 28-01-2015, 17:47
Software Architect
Driving a six-wheel skid-steer drivebase using Tank Drive (left and right joysticks) is not easy if the robot doesn't want to go straight, even with computer control based on a gyro sensor. It is very easy to make it go straight using Tank Drive if the robot is properly constructed.
But if you really want to try to compensate for a difficult-to-control robot, the idea is simple. Compute the difference between desired and measured heading, scale it to something that will yield a value between -1 and 1, then add it to the joystick input for one side and subtract it from the joystick input for the other side.
Unread 28-01-2015, 18:14
Rookie Year: 2013
two cims on each side.
