Go to Post That goal is going to commit suicide by the end of the regional........so many balls @_@... - DanDon [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 27-01-2015, 17:38
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
Rookie Year: 2011
BrighidKHeh is an unknown quantity at this point
Java JRE/FRC Java Installer - Help Needed
I went to http://wpilib.screenstepslive.com/s/...y#!prettyPhoto to follow the instructions on how to download Java onto the RoboRio, however, the links we are sent to are for Linux downloads and we are not able to find any Windows downloads. Where can I find a Windows download for the embedded file? Also, how do we get the FRC Java Installer?
Unread 27-01-2015, 17:43
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Java JRE/FRC Java Installer - Help Needed
The Java installer is installed with the Eclipse plugins and is located found at: USER_DIR/wpilib/tools/java-installer.jar. You should be able to install the JRE on to the roboRIO by following the instructions in the installer.
The reason you are downloading a Linux JRE is because it is being installed on the roboRIO, which runs Linux.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 27-01-2015, 17:58
Rookie Year: 2011
I get an error whenever I attempt to download the necessary files though. All the the .gx Linux ones from Oracle.
Unread 27-01-2015, 17:59
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
What error?
Unread 27-01-2015, 18:22
Rookie Year: 2011
It is unable to find the .gz file and it asks me to look on the internet for a solution.
Unread 27-01-2015, 18:44
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
Were you able to get to the download page and create an Oracle account, and if so did it start downloading the file? Posting a screenshot might help diagnose the problem.
Unread 27-01-2015, 19:38
Rookie Year: 2011
So we got to the FRC Installer, but now when we download those files onto them, it says "This JRE does not pass vile verification".
Unread 27-01-2015, 19:48
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
I think you need to update your Eclipse plugins. There was an update published on 1/23 to fix an issue with the Java Installer pointing to the wrong page after a JRE update changed the website.
Unread 27-01-2015, 21:10
pr0ph3t pr0ph3t is offline
Programming and Controls Mentor
AKA: Jeff Ousley
FRC #3528 (Up Next)
Team Role: Coach
Rookie Year: 2011
pr0ph3t is an unknown quantity at this point
We're having the same issue. We updated the eclipse plugins and are trying to install:
Code:
ejdk-8u33-fcs-linux-arm-sflt.tar.gz
We've tried both downloading it ourselves and letting the installer download it. We are able to install the previous version:
Code:
ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz
Are we supposed to be able to update to the newer version? The instructions here:
http://wpilib.screenstepslive.com/s/...ller-java-only
are not clear.
Unread 27-01-2015, 21:20
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
When you update the Eclipse plugins, the Java installer should have you download the old JRE, so that is what you should use. I guess they don't want us to update to the newer version.
