Go to Post buying an iPhone...$599. Monthly service charge...$59. Going to an Apple store just to post on CD... Priceless!:p - Schnabel [more]
Unread 27-01-2015, 18:40
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Data from BuiltInAccelerometer
I currently don't have access to the roboRIO (well... access to the ability to send it flying across the room at 13 feet per second) untill later in the build season so I was wondering if anyone had any data regarding reads from the accelerometer, specifically converting the g's from the accelerometer at setpoints.
Thanks!
Note: I realize Z might differ slightly based on altitude of the testing facility, I'm not so concerned in that as I am x-y
Unread 27-01-2015, 18:48
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Data from BuiltInAccelerometer
Converting them to what? And what do you mean by "setpoints" in this context?
Unread 27-01-2015, 19:06
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
FPS (feet per second).
by "setpoints" i mean something like
"at defined 3 feet per second the accelerometer was reading 1g"
"at defined 5 feet per second the accelerometer was reading 1.5g"
"at defined 9 feet per second the accelerometer was reading 2g"
known feet per second / accelerometer g reading pairs.
Unread 27-01-2015, 19:10
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Velocity is not proportional to accelerometer readings. Accelerometers measure acceleration. You would need to integrate accelerometer readings to get velocity.
Unread 27-01-2015, 19:46
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Oh, that makes sense. Than, 1g should be proportional to 32.1740486 ft * s^-1 * s^-1. I feel dumb now.
Thanks!
E/ the neutral reading of the accelerometer seems to oscillate around 0.002 and 0.004. (not 0.2 and 0.4)
Within 10 seconds, this would give the incorrect reading of ten feet per second if integrated.
Has anyone even got the accelerometer to work properly?
Unread 28-01-2015, 01:02
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
The math is trivial with the assumption that the robot never turns.
As soon as the robot turns, or goes up/down over the scoring zone, the math gets complex really quickly.
Then, you have to map the xyz space of the roboRio to your xyz space (you don't want to assume that the accelerometer in the roboRio is exactly flat to the base of the roboRio, and that the roboRio is mounted in a plane parallel to the floor.
Unread 28-01-2015, 08:14
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
A little bit off topic, but. I was listening on the radio today about a basket ball with sensors (I assume an accelerometer hence the slight topic correlation) that tracks its movement and transmits to a smart phone app. So if you can do it through 3D space, you should be able to do it on a robot in 2d space with something that weighs less than a basketball.
If you don't know what you should hook up then you should read a data sheet
Unread 28-01-2015, 11:59
Joshua Sicz Joshua Sicz is offline
FRC #2403
Joshua Sicz is an unknown quantity at this point
I would be very careful with this because it is very hard to get velocity with acceleration from something like the built in accelerometer. Our team has messed with it alot and found there is no good way to figure it our because you have a LOT of noise comming from it. The only real use we found is just telling which direction the robot is going.
The earth has a huge force that is hard to get rid of. If you want to get something accurate enough to tell velocity you might want to go get the NavX board sold my andymark but even with that board the velocity is only accurate for only about 2-3 seconds before it starts to get off.
If the accelerometer was accurate enough to tell speed we would have used them in cars on such. But because of the earth it won't be useful as you think it would. What you learn in physics is only ideal situation.
Unread 28-01-2015, 12:05
Ether's Avatar
Rookie Year: 1969
The above is a bit ambiguous. How does an accelerometer tell which direction the robot is going?
Unread 27-01-2015, 19:11
Ether's Avatar
Rookie Year: 1969
I see RufflesRidge beat me to it.
