Go to Post Progress should never made at the expense of the past. - Koko Ed [more]
Unread 27-01-2015, 21:37
tigerbytesSENT tigerbytesSENT is offline
FRC #3192
tigerbytesSENT is an unknown quantity at this point
Exclamation Compiling throws connection error for working roborio
For the past couple of hours, our team has continually attempted to update the code on our controller with no avail. Every attempt ends at Java.io.IOException: Connection is not open.
However, the driver station connects perfectly fine to the roborio, and we can drive with the code we previously uploaded. Uploading code worked just last week as, so we have no idea what happened in the interim that caused this issue.
So far we have tried:
Reconfiguring the radio
Reflashing the Rio
Connecting to the Rio with both wireless comms and with ethernet
Connecting using differenct computer.
We're stuck, not even our mentor knows what is wrong with the robot. Any help in resolving this issue is greatly appreciated.
If it helps any, we are using Netbeans and the NI 2014 Java Plugins.
Unread 27-01-2015, 22:36
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Compiling throws connection error for working roborio
Can you give a pastebin link with your code and the error?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 27-01-2015, 22:44
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Are you sure? I don't know of any NI Java Plugins and the official plugins for the roboRIO are the 2015 Eclipse plugins.
Unread 28-01-2015, 16:15
FRC #3192
Exclamation Re: Compiling throws connection error for working roborio
We were able to compile and upload code with the plugins on NetBeans before, so I'm not sure why its causing a fit now. We suspect its the environment causing the issue, but we are not sure why. I will upload the code we tried to deploy when possible.
Unread 29-01-2015, 01:35
viggy96 viggy96 is offline
FRC #3331
Rookie Year: 2010
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
You have to use Eclipse this year. The RoboRIO only work with those plugins.
