Go to Post I could say that the decline in the population of pirates is responsible for global warming, the statistics correlate, but its obvious there's no causation there. - Racer26 [more]
Unread 28-01-2015, 16:35
TBots TBots is offline
FRC #3350
TBots is an unknown quantity at this point
RoboRIO requires imaging prior to each deploy
We have been having issues deploying code to our roboRIO. Ever time we try to deploy code as start up, we get an issue saying the target cannot be found. However, when we reformat the roboRIO prior to the deploy it works correctly. It takes about 7 minutes each time we reformat the RIO and is causing quite a hassle to do this each time. If anyone could help us understand why this is occurring, that would be fantastic
We are using lab view.
Unread 28-01-2015, 17:05
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: RoboRIO requires imaging prior to each deploy
Is that true even with a newly created default LabVIEW project. That test would at least rule out anything in your robot logic, or narrow it down to something with your robot app.
Unread 28-01-2015, 17:10
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Do you see the same issue if you just press "Run" from Robot Main.vi?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 28-01-2015, 17:35
FRC #3350
Neither of those deploy correctly. We still get the same error that the target can not be found.
I don't know whether this contributes to the reason it isn't working, but every time we create a new roboRIO project in Labview, it does not build correctly unless we delete the visual processing VI. It appears to have missing and broken VIs dealing with the camerea
Unread 28-01-2015, 17:49
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Originally Posted by TBots View Post
I don't know whether this contributes to the reason it isn't working, but every time we create a new roboRIO project in Labview, it does not build correctly unless we delete the visual processing VI. It appears to have missing and broken VIs dealing with the camera
It's unrelated to your target problem.
That's probably due to the Vision license not being activated properly.
See if this post helps with that problem.
For the deploy problem could it be related to this issue?
Are the symptoms similar?
Waiting for Target to Respond - Recovering from bad loops
Unread 29-01-2015, 14:00
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
I don't know about the Labview deploy (we use C++), but it sounds like the computer running cannot resolve the ip address for the roborio. Some ideas:
- have you tried usb and Ethernet?
- have you waited awhile so that the mDNS responses might work?
- did you try a different computer? The driver station image comes with Labview.
- can you ping the roborio? Can you log into its console with ssh or ftp?
- try looking in the router setup and get the ip address of the robo-rio. As a hack, you could try putting that in the hosts file on your pc for roborio-team.local. Note this is a total hack and not recommended to leave in. Back out the change after trying it.
Brian K
Team 1225 Robotics Mentor
Unread 02-02-2015, 17:24
FRC #3350
Thank you for all of the suggestions! It turns out it was actually a very simple problem. We were trying to deploy our code via Ethernet cable through the D-LINK, when we should of been using an USB A to USB B cable to deploy code directly to the roboRIO! This is why it appeared that the roboRIO had to be re-imaged each time, when it reality all we had to do was connect the cord. Again, thank you for the all the help!
Unread 02-02-2015, 17:54
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
You should be able to deploy your code through ethernet and the D-Link; it looks like you have some other problem.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 02-02-2015, 18:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What is the target address (in parentheses) on the Real-Time Target line in your LabVIEW project?
Unread 08-02-2015, 20:33
Ro13star Ro13star is offline
FRC #0832
Ro13star is an unknown quantity at this point
We are having the same problem. I temp fixed it for the "run" option by disabling startup rt and fpga in Web dash. I saw a more advanced error message saying a component encountered an unexpected error and had to restart. I heard something about using the "clean" option before deploying but I'm not sure if that applies to LabVIEW?.
