Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Unread 28-01-2015, 17:29
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Issue with Mecanum Test Code
I uploaded this code and the second I press Enable for teleop the robot goes crazy and all the motors fire. This program is only made to straffe and go forwards/backwards.
Here it is:
Code:
package org.usfirst.frc.team4623.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
	public XBox stick = new XBox(0);
	SpeedController frontLeftMotor = new Jaguar(0);
    SpeedController frontRightMotor = new Jaguar(1);
    SpeedController rearLeftMotor = new Jaguar(2);
    SpeedController rearRightMotor = new Jaguar(3);
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
     * This function is run once each time the robot enters autonomous mode
     * This function is called periodically during autonomous
     * This function is called once each time the robot enters tele-operated mode
    public void teleopInit(){
     * This function is called periodically during operator control
                   mecanumDrive(
                    (XBox.LEFTJOY_X+XBox.LEFTJOY_Y)/2,
                    (XBox.LEFTJOY_Y-XBox.LEFTJOY_X)/2,
                    -(XBox.LEFTJOY_Y-XBox.LEFTJOY_X)/2,
                    -(XBox.LEFTJOY_X+XBox.LEFTJOY_Y)/2);
     * This function is called periodically during test mode
    public void testPeriodic() {
    	LiveWindow.run();
    public void mecanumDrive(double FL, double RL, double FR, double RR)   {
        frontLeftMotor.set(FL);
        rearLeftMotor.set(RL);
        frontRightMotor.set(FR);
        rearRightMotor.set(RR);
It is pulling XBox stuff from this class:
Code:
 * @author FrankyMonez
public class XBox extends Joystick{
    public XBox(int port) {
        super(port);
    public static final int
            A_BUTTON = 1,
            B_BUTTON = 2,
            X_BUTTON = 3,
            Y_BUTTON = 4,
            START_BUTTON = 8,
            BACK_BUTTON = 7,
            LS_BUTTON = 9,
            RS_BUTTON = 10,
            RB_BUTTON = 6,
            LB_BUTTON = 5,
            LEFTJOY_Y = 2,
            LEFTJOY_X = 1,
            RIGHTJOY_Y = 5,
            RIGHTJOY_X = 4,
            LEFT_TRIGGER = 3,
            RIGHT_TRIGGER = 3;
    public boolean getButtonA() {
     return getRawButton(A_BUTTON);
    public boolean getButtonB() {
        return getRawButton(B_BUTTON);
    public boolean getButtonX() {
        return getRawButton(X_BUTTON);
    public boolean getButtonY() {
        return getRawButton(Y_BUTTON);
    public boolean getButtonRB() {
        return getRawButton(RB_BUTTON);
    public boolean getButtonLB() {
        return getRawButton(LB_BUTTON);
    public boolean getButtonRS() {
        return getRawButton(RS_BUTTON);
    public boolean getButtonLS() {
        return getRawButton(LS_BUTTON);
    public boolean getButtonStart() {
        return getRawButton(START_BUTTON);
    public boolean getButtonBack() {
        return getRawButton(BACK_BUTTON);
    public double getLeftJoyY() {
        return getRawAxis(LEFTJOY_Y);
    public double getLeftJoyX() {
        return getRawAxis(LEFTJOY_X);
    public double getRightJoyY() {
        return getRawAxis(RIGHTJOY_Y);
    public double getRightJoyX(){
        return getRawAxis(RIGHTJOY_X);
    public double getRightTrigger() {
        return -Math.min(getRawAxis(RIGHT_TRIGGER), 0);
    public double getLeftTrigger() {
        return Math.max(getRawAxis(LEFT_TRIGGER), 0);
THANKS for the help!
