Go to Post Where's the easy button on this thing... - Akash Rastogi [more]
Unread 28-01-2015, 18:24
MattOz MattOz is offline
FRC #5416 (TaRDIS)
Team Role: Leadership
Rookie Year: 2015
MattOz is an unknown quantity at this point
Dart Linear Actuators Motor Sub.
Can any of the smaller standard VEX motors be substituted for the CIM motor on Dart Linear Actuators and if so what is required to make the transition?
Very Much Appreciated!!!
Unread 28-01-2015, 18:38
Andrew Lawrence
Posts: n/a
Re: Dart Linear Actuators Motor Sub.
What is your definition of "standard VEX motors"? If you mean the Mini CIM and the BAG motor, both can fit to the CIM mount interface (the Mini CIM directly mounts, and the BAG motor would have to go through a VersaPlanetary). Keep in mind swapping motors will change the output torque, so you'll have to do your own math in those regards, but it's relatively simple. If you're referring to the VEX 393 servomotors, I'm sure a custom connection could be made, but I can't see why you would want to do that.
Unread 28-01-2015, 18:45
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Essentially you want a gearbox with a "CIMlike" output.
Vex has the versaplanetary (500, 700 and bag motors), and the cim-i-lie (500, 700 and bag motors).
Banebots has the cimulator (500, 700 motors).
Andymark has the AM planetary (500 size motors)
Unread 29-01-2015, 08:22
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Yes this can be done as seen this video.
https://www.youtube.com/watch?v=I7jfwprVXMY
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
