Go to Post Does FIRST know about some rare inverted mushroom that I do not? - sanddrag [more]
Unread 28-01-2015, 20:25
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
Rookie Year: 2012
dvanvoorst is an unknown quantity at this point
Vision Assistant particle report
I'm having trouble finding the particle report option in Vision Assistant. Has it been removed in this years software? If not, where can I find it?
Thanks in advance!
Dale
Unread 28-01-2015, 20:33
Re: Vision Assistant particle report
Fourth tab over, the monitor wit red blobs on it. Sixth item down.
You can also drop functions from the menubar -- Binary, just below the line.
Greg McKaskle
Unread 28-01-2015, 20:55
Rookie Year: 2012
Hi Greg,
I only have the "Basic Morphology" choice in both of those locations.
I'm running Vision Assistant Version 2014 with a target of NI myRIO-1950. Did I miss some installation step and get a reduced functionality version?
Thanks
Dale
Unread 28-01-2015, 21:16
What happens if you do not target a myRIO?
Greg McKaskle
Unread 28-01-2015, 21:20
Rookie Year: 2012
That fixes it! I switched it to Labview, and now I see the full menu options. I probably picked the myRIO when I installed the software, assuming that I had to pick something that matched the hardware. Bad idea I guess.
Thanks for the help!
Dale
