Go to Post Yes, no more dancing. Robots is serious business :rolleyes: - wilsonmw04 [more]
  #46   Spotlight this post!
Unread 20-02-2015, 05:33
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: Help Calculating time to recharge air tanks
Originally Posted by Richard Wallace View Post
I am not an expert, but my team has made some tests which may shed some light. See attached summary of our set up and results for recharging a 48 cubic inch system using three FRC-legal compressors.
When recharging from ~100 to ~120 PSI, the compressor must start against load. As Mr. V pointed out above, this case is much more pertinent to actual FRC operation than the tests I reported earlier.
The initial peak surge current observed using Viair compressors is relatively short duration (<0.1 sec), but the Thomas compressor's initial peak surge current is much longer duration (~0.5 sec). Comparing the Thomas surge against typical automotive fuse curves suggests an explanation for the "conventional wisdom" Jon mentioned above. The Thomas compressor has much less margin against blowing a 20A fuse during surge, and historically that is the compressor on which our FRC "conventional wisdom" is based.
Richard HI
I try the test. noting move may be because of the spike, I use defrent spike , nothing move.
TEAM 1946-Tamra
  #47   Spotlight this post!
Unread 20-02-2015, 05:58
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Originally Posted by yara92 View Post
Richard HI
I saw your questions in the other thread. Have you been able to determine if your Thomas compressor is still functioning normally? Do you have another compressor to try?
Richard Wallace
since 2003
  #48   Spotlight this post!
Unread 20-02-2015, 13:14
yara92's Avatar
AKA: Mohamed
YesI have ,
for testing Iconnect dirict itis working.
My quation i you knowhow to use the spike as relay. I use Jumber, the output 0 [V]
TEAM 1946-Tamra
  #49   Spotlight this post!
Unread 20-02-2015, 14:40
Rookie Year: 1996
YesI have ,
Ok, now I understand your question. I caused confusion by showing the control connection between the pressure switch and the Spike incorrectly in the diagram attached in my earlier post. The connection used on my team's bench test board is shown in the attached (revA) version of that diagram.
Richard Wallace
since 2003
