Go to Post A robot is never "complete" - [more]
Unread 29-01-2015, 11:49
Dinnesy Dinnesy is offline
FRC #4968 (Robo Hawks)
Team Role: Teacher
Rookie Year: 2014
Dinnesy is an unknown quantity at this point
Code changes not deploying to robot?
My team has deployed the following code to our robot:
package org.usfirst.frc.team4968.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
public class Robot extends SampleRobot
RobotDrive myRobot; // class that handles basic drive operations
Joystick leftStick; // set to ID 1 in DriverStation
Joystick rightStick; // set to ID 2 in DriverStation
public Robot()
myRobot = new RobotDrive(0, 1);
myRobot.setExpiration(0.1);
leftStick = new Joystick(0);
rightStick = new Joystick(1);
public void operatorControl()
myRobot.setSafetyEnabled(true);
while (isOperatorControl() && isEnabled())
myRobot.arcadeDrive(leftStick);
//myRobot.tankDrive(leftStick, rightStick);
Timer.delay(0.005); // wait for a motor update time
Initially, the code was working. However we then tried redeploying the code with a few changes, and the robot stopped working. So, we reverted the code back to EXACTLY what it was when it was working, and redeployed it, but the robot still does not work. I believe this to because by our code is not successfully deploying to the robot, because no matter what we do, nothing seems to change and the robot does not respond. Could someone outline the code deploying process for us to ensure we are not missing anything? Does the build.xml file need to be updated?
Unread 29-01-2015, 11:53
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Code changes not deploying to robot?
Before doing anything else, try using some System.out.println statements to make sure whether the code is or is not getting updated on the bot.
Unread 29-01-2015, 12:23
Team Role: Teacher
Rookie Year: 2014
We have a very new and inexperienced coder this year and he is not very familiar with system.out.println statements, could you explain how we would do so? Thanks a Lot!
Unread 29-01-2015, 12:43
AKA: Josh P.
Rookie Year: 2007
System.out.println("Hello world"); will print a line of text containing "Hello world" in the console. You can substitute any string for "Hello world".
Then you can look at the console output to see if your text is printing.
Unread 29-01-2015, 12:59
Team Role: Teacher
Rookie Year: 2014
I get the hello world printout infinitely in the console. So, that would imply that there is an issue with my code, however i am not getting any errors, and all of the ports are correct.
Unread 29-01-2015, 13:14
AKA: Josh P.
Rookie Year: 2007
All that means is that you put that statement in a loop (this is okay). More importantly, it means that your code is being deployed and updated properly.
Unread 29-01-2015, 13:54
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The posted code is just for driving the robot... Have you verified through the driver station that the joysticks are still connected?. Unplugging them and then plugging them back in while the driver station is up can cause them to no longer be recognized or read.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 30-01-2015, 09:40
Team Role: Teacher
Rookie Year: 2014
Yes, they joysticks are connected and the driver station is recognizing all feedback from them.
Unread 30-01-2015, 09:48
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
What do the lights on the motor controllers do when you enable the robot?
Also, when posting code, please use code tags to make it easier to read. To use a code tag place a [/code] at the end and a [code] at the beginning. Thanks.
Unread 30-01-2015, 10:03
Team Role: Teacher
Rookie Year: 2014
the light on the motor controllers(talons) do not change when the robot is enabled, they are always flashing orange. I will use the code tag from now on, sorry.
Unread 30-01-2015, 10:05
Flywheel Police
No need to apologize, most people don't know about them. It just makes it easier to read.
The flashing talons means that they are note being communicated with. Can you verify that the talons are plugged into the correct ports and that they are plugged in correctly?
Unread 30-01-2015, 11:46
Team Role: Teacher
Rookie Year: 2014
I took a look at the pwm's and it turns out that someone had put them back in incorrectly when we moved the drive base over. So now, the code is working and we have made some modifications to it. However, our left and right turning seems to be inverted. could anyone tell me how to modify it so that it turns correctly? I have tried changing the pwm ports but it has not effect.
Updated Code:
Code:
 * This is a demo program showing the use of the RobotDrive class.
 * The SampleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SampleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
 * WARNING: While it may look like a good choice to use for your code if you're inexperienced,
 * don't. Unless you know what you are doing, complex code will be much more difficult under
 * this system. Use IterativeRobot or Command-Based instead if you're new.
public class Robot extends SampleRobot {
    RobotDrive myRobot;
    Joystick stick;
    public Robot() {
        myRobot = new RobotDrive(1, 0);
        stick = new Joystick(1);
     * Drive left & right motors for 2 seconds then stop
    public void autonomous() {
        myRobot.setSafetyEnabled(false);
        myRobot.drive(-0.5, 0.0);	// drive forwards half speed
        Timer.delay(2.0);		//    for 2 seconds
        myRobot.drive(0.0, 0.0);	// stop robot
     * Runs the motors with arcade steering.
    public void operatorControl() {
        while (isOperatorControl() && isEnabled()) {
            myRobot.arcadeDrive(stick); // drive with arcade style (use right stick)
     * Runs during test mode
    public void test() {
Thanks again!
Unread 30-01-2015, 11:51
Flywheel Police
Updated Code:
Code:
 * directory.
    RobotDrive myRobot;
    Joystick stick;
    public Robot() {
Thanks again!
I'm guessing you have your motor ports backwards, try changing it to this:
Code:
myRobot = new RobotDrive(0, 10);
RobotDrive takes in the left side, then the right side.
Unread 30-01-2015, 12:06
Team Role: Teacher
Rookie Year: 2014
Code:
I applied your change and redeployed the code, however nothing has changed. I'm still getting the same issue. any other idea's?
  #15   Spotlight this post!
Unread 30-01-2015, 12:07
Flywheel Police
Oops, that should be (0, 1) not (0, 10).
