Go to Post The reason I care about it is that I don't want minorities (whether that's females or other racial minorities) to see the STEM world as only inclusive of majorities or men. - Monochron [more]
  #16   Spotlight this post!
Unread 29-01-2015, 13:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pneumatic tubing swelling
Originally Posted by Batterink View Post
We'll see about mounting a fan to cool it this evening.
Thanks everyone.
You're welcome!
You don't need to attach the fan to the compressor itself. It would be better to mount the fan next to, or over, the compressor so it blows air across the compressor head (the part with cooling fins on it). You can mount the fan several inches away, and it will still work well to keep it cool.
  #17   Spotlight this post!
Unread 29-01-2015, 16:44
Batterink Batterink is offline
FRC #4519
Batterink is an unknown quantity at this point
We figured out that it's the heat issue. We're going to set up a fan, and add some more tanks (likely).
Thanks for the help guys and gals.
  #18   Spotlight this post!
Unread 05-02-2015, 09:51
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Originally Posted by Ronnie314 View Post
Would you mind PM me a picture of how you attacked the fan to the compressor? We are just using zip ties at the moment. The fan keeps the compressor WAY cooler but worried about the zip ties possibly being melted.
-Ronnie
Here is a picture of how we mounted the fan last year.
https://drive.google.com/file/d/0B6s...ew?usp=sharing
  #19   Spotlight this post!
Unread 05-02-2015, 09:54
MrForbes's Avatar
AKA: Jim
One of our students brought in a COTS computer fan, with a built in mounting bracket, it seems to work ok. We don't have a lot of pneumatics on our robot this year, so it won't be running the compressor often.
  #20   Spotlight this post!
Unread 05-02-2015, 10:49
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Post Re: pneumatic tubing swelling
Be careful with this... R18 is very specific, and there was a relevant Q&A.
https://frc-qa.usfirst.org/Question/...-rather-confus
The way I read Q &A 142, you can only use a COTS Computer fan is it is part of a computing device on the robot... I don't think pulling a fan out of a computer and using only the fan is legal.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
  #21   Spotlight this post!
Unread 05-02-2015, 10:54
MrForbes's Avatar
AKA: Jim
Thanks....the fan is part of a COTS computing device, but we did not install the computing device on the robot. The wording is still ambiguous, since it doesn't specifically state that the COTS computing device (that the fan was removed from) must also be installed on the robot. I guess we'll see about changing the fan.
  #22   Spotlight this post!
Unread 05-02-2015, 15:37
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
Originally Posted by Jon Stratis View Post
...It also comes with a steel mesh leader hose - this is considered part of the compressor (per last year's Q &A, at least... I haven't seen it asked this year yet), and can be used to help ensure the tubing is well away from the hot parts of the compressor!
Al chimed in with his opinion earlier this year (I know, that doesn't make it official )
Originally Posted by Al Skierkiewicz View Post
As a caveat, the Viair above comes with a stainless steel hose that is required for operation by the manufacturer. The hose helps dissipate the heat generated by the compressor and compressed air.
but, at last check, hasn't been posted to the Q&A yet.
(We've used it in the past, but don't expect to this year - our pneumatic load isn't that high.)
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
