Go to Post They really should put warning signs at all entrances: "WARNING! FIRST IS CONTAGIOUS!" - KenWittlief [more]
Unread 29-01-2015, 16:30
TeamMarcies TeamMarcies is offline
FRC #4777
TeamMarcies is an unknown quantity at this point
Issues with the Gyro - Help
Hey!
We've been trying for hours to fix the issue with our Gyro and we're not sure whether it's a software issue or hardware issue.
Here is our wiring (i only posted links since they are huge images):
http://i.imgur.com/ChcTKaV.jpg
http://i.imgur.com/6MXDKSq.jpg
As we rotate our gyro, we're expecting the gyro pointer to move but it isn't:
http://puu.sh/fcJgn/209d7ff45f.jpg (when we are connected to joystick/communication/code)
This is our code snippet for the gyro to drive forward straight and to drive backwards straight.
Btw, the gyro.reset(); is already called before this thread starts.
Code:
        public double gyroSensitivity = 0.05; // (voltage / 1000)
	public void run() { // This method is executed only for DriveForward and
						// DriveBackward
		r.autonomousCounter = 0;
		r.theRobot.setExpiration(0.1);
		while ((Math.floor(r.autonomousCounter / r.loopsPerSecond)) <= DriveClass.seconds) {
			if (RecycleRush.InTeleop) {
				break;
			if (forward) {
				r.theRobot.drive(r.robotDriveSpeed, -r.gyro.getAngle() * r.gyroSensitivity);
			} else if (!forward) {
				r.theRobot.drive(-r.robotDriveSpeed, -r.gyro.getAngle() * r.gyroSensitivity);
			Timer.delay(r.timerDelay);
		r.theRobot.drive(0.0, 0.0);
It drives forward, but does not drive complete straight - same for backwards.
We also made code to make it rotate while its stationary.... We made two methods, one of which we deprecated for now because we found simpler logic.
Code:
	public void DriveRotate(int rotateAngle) {
		r.queueThread(new Runnable() {
			public void run() {
				r.gyro.reset();
				while (r.gyro.getAngle() < rotateAngle) {
					r.theRobot.drive(0.0, 1);
	/* DEPRACATED METHOD
			public void run() {
				r.gyro.reset();
				double angleHeader = r.gyro.getAngle(); // Initial Angle
				while (Math.abs(angleHeader - r.gyro.getAngle()) <= Math.abs(rotateAngle)) { // Rotating
					r.theRobot.drive(0.0, rotateAngle * r.gyroRotationSpeed);
					DriverStation.reportError(r.gyro.getAngle() + "", true);
We have the Gyro connected to: 0 so this is our declaration:
Code:
    // Gyro - Handles Trajectory Paths
    public int GyroChannel = 0;
    public Gyro gyro = new Gyro(GyroChannel);
Basically, the Gyro isn't working in any way.
