Go to Post I'm exceptionally bad at taking my own advice, is all. - Libby K [more]
Unread 01-29-2015, 04:52 PM
IrishFBall32 IrishFBall32 is offline
Electrical CDT Mentor
AKA: Chris Bowles
FRC #1014 (Dublin Robotics/Bad Robots)
Team Role: Electrical
IrishFBall32 is on a distinguished road
Send a message via AIM to IrishFBall32
Tweaking PWM output period for dimming LEDs
Hi all, I'm working on an LED driver circuit and wanted to run this by y'all.
The circuit I'm building is a simple TIP120 transistor based amplifier, which I intend to be connected to PWM outputs on the RoboRIO, with the pulsed output effectively modulating the duty cycle of the LEDs.
The snag I'm running into relates to PWM duty cycles. Ideally, I'd like 0% to be an output of 0vdc, and 100% to be a constant output of 6vdc. 50% would then be 6vdc pulsed at say 1ms on, 1ms off. From my understanding the default PWM signal is a 1-2ms pulse every 20 seconds, which translates to a 5-10% duty cycle. I see references in the WPILib API's PWM class to varying the PWM period potentially down to 5.05ms, and pulses as small as .5ms (which should get me ~10-40%), but does anyone know if it is possible to manipulate the PWM output further? I'm also open to other suggestions such as an efficient way to pulse a DIO pin in the necessary manner.
Disclaimer: I've read the API docs, but I haven't dug into the actual code. I also haven't yet resorted to just tinkering with things and seeing what I get with an oscilloscope.
Chris Bowles
Team 1014 - Dublin Robotics (Bad Robots)
2015 Electrical CDT Mentor
2006 Controls CDT Leader
2005 Controls CDT Member
Unread 01-29-2015, 05:12 PM
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Tweaking PWM output period for dimming LEDs
The PWM signal sent from the roboRIO is a Hobby PWM signal, slightly different from a typical duty cycle. I would use a digital pin and create my own function to adjust the duty cycle.
Would the analog outputs on the MXP be an option?
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 01-29-2015, 06:00 PM
wmarshall11 wmarshall11 is offline
FRC #2399
Rookie Year: 2011
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
I've previously used PWM.setRaw() to set the duty cycle of PWM channels for driving LEDs, where setRaw(0) is 0% duty cycle and setRaw(255) is 100%.
Unread 01-29-2015, 09:53 PM
Bonzabonz Bonzabonz is offline
FRC #5052 (RoboLobos)
Rookie Year: 2014
Bonzabonz is an unknown quantity at this point
My team had to do the same thing; there are functions to get a DIO pin to output a PWM signal of a user specified frequency. We did it using LabVIEW, but it should work in a similar way using Java or C++. If you just need to open the DIO pin as normal, you can use the Gen PWM VI to set your duty cycle. There is an additional VI abbreviated Config PWM Rate where you can actually change the frequency of the signal for the DIO pin.
I was also able to find documentation for the Java DigitalOutput class here: http://first.wpi.edu/FRC/roborio/rel...e4aab985133c41 . There are setPWMRate(), enablePWM() and updateDutyCycle() methods to control the PWM functionality for a specific DIO pin. The API should have more details on how to implement them.
Unread 01-29-2015, 11:54 PM
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Chris
How many LED's are you trying to drive? If you are driving multiple LED's, are they connected in series? How many are connected in series?
Unread 02-02-2015, 08:05 PM
AKA: Chris Bowles
Thanks guys, I'm taking a look at those methods now.
As for the number of LEDs, its one of the ubiquitous RGB LED strips. If you're working toward the usual warning about current draw on the PWM pins, I'm quite aware, hence the transistor amp.
Chris Bowles
