Go to Post i will not post here...i will not post here....well...okay, yes I will - David66 [more]
Unread 29-01-2015, 17:18
Team3220's Avatar
Team3220 Team3220 is offline
Mechanic of Mayhem
FRC #3220 (Mechanics of Mayhem)
Rookie Year: 2013
Team3220 is an unknown quantity at this point
How Should I Learn C++?
I'm a junior this year, and want to learn enough C++ to code a robot by next year. Is this a realistic goal? Can anyone recommend any good books or videos or websites for learning C++? My high school doesn't offer any programming classes, so I'm kind of on my own.
Unread 29-01-2015, 17:34
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: How Should I Learn C++?
It is not easy, but this is certainly an achievable goal, as long as you stick with it.
I carried around this book with me everywhere I went my junior year, and was able to get up to speed quite quickly (ignore the 21 days thing). Look for the latest edition. The best thing I like about this book was the detailed code examples along the way.
Aside from that, the most important thing to do is to just code. Write code as much as you can. Get excited about it! If you have a mentor, ask questions (if not, ask here or other C++ forums). If you have anyone to learn with, do the same problems, compare answers and learn from each other. Reading a book or attending a class will only get you so far. Find some problems to do and try it. Write some code, learn from mistakes, experiment with it. There are plenty of programming problems and a lot that you can learn with just the basic tools (i.e. outside of using the robot, from just an IDE such as Code::Blocks).
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
https://wpilib.screenstepslive.com/s/4485/m/13810
Unread 30-01-2015, 01:41
SoftwareBug2.0's Avatar
SoftwareBug2.0 SoftwareBug2.0 is offline
AKA: Eric
FRC #1425 (Error Code Xero)
SoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant future
I think that to properly answer this question I'd have to know where you're starting from: Are you new to programming? Do you already know some other language? Do you already know C but not C++? Depending on which of these is the case I would recommend different things.
Unread 30-01-2015, 02:30
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
Rookie Year: 2011
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Here is the intro to c++ class at University of Missouri of Science and Technology notes / assignments.
http://classes.mst.edu/compsci1570/
It has videos too.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 30-01-2015, 14:42
Team3220's Avatar
Mechanic of Mayhem
Rookie Year: 2013
I've done some programming in Python, not a ton. I go to a small farm school, and no one really knows anything about computers. I'm working with my principal and counselor to get a programming independant study class. I"ve read that C++ is a very useful language to know, so I figured it would be advantageous to get a jump on it before college. Plus I feel like being able to code a robot in C++ would be a good goal to work towards.
