Go to Post Seating is limited. Be sure to apply deodorant and brush your teeth. - Wayne TenBrink [more]
Unread 29-01-2015, 19:11
Governators3361 Governators3361 is offline
FRC #3361
Governators3361 is an unknown quantity at this point
Talon SR's not getting power
We have a test control system wired with one motor. The indicator light turns on, the RoboRio is powered correctly, and the motor controller is wired per the instruction manual. However, the LED is not turning on on the Talon, nor does a voltmeter read anything and the connected motor does not work. How can we get power supplied to the controller?
If it helps, our Power Distribution Panel is blinking slow red.
Please respond soon!
Unread 29-01-2015, 19:15
FRC #3361
Re: Talon SR's not getting power
60 seconds later....
We figured it out. We were missing the snap circuit breaker on the PDP.
