Go to Post I guess the freshmen had to learn the hard way, never turn your back on a robot. - Bcahn836 [more]
Unread 29-01-2015, 20:16
seshaw415 seshaw415 is offline
AKA: Seiji Shaw
FRC #6000 (Firehawk Robotics)
Team Role: Leadership
Rookie Year: 2014
seshaw415 is an unknown quantity at this point
Exclamation RoboRio Java Installation Problem
Hello,
I am currently having trouble installing java on the roboRio. Everything runs smoothly to the point the where the installer needs to deploy the JRE to the roboRio. Afterwards, the process seems to take incredibly long (never finished) to deploy while saying "Tarring created JRE." I even let it run for about for a hour and a half once.
I have already updated the roboRio's firmware and re-imaged it many, many times to get it to work, but the end result is always the same.
Is there anything I am doing wrong to fix this?
Thanks
Unread 29-01-2015, 20:46
MatthewC529 MatthewC529 is offline
Lcom/mattc/halp;
AKA: Matthew
FRC #1554 (Oceanside Sailors)
Rookie Year: 2013
MatthewC529 is on a distinguished road
Re: RoboRio Java Installation Problem
Please first make sure you are following the steps exactly:
http://wpilib.screenstepslive.com/s/...ller-java-only
I know this may not be a particularly helpful answer but I am covering my bases. It may end up in you having to install the jre yourself over ssh using the parameters the WPI team used. I believe Kevin O'Connor or another one of the software developers posted them at one point. I will see if I can track them down if worse comes to worse.
Though they do have a few tips on the ScreenSteps Live page.
Oh and what fsilberberg said. That is a useful thing as well.
Team 1554 -- Oceanside Sailors
  • 2013-2014 - Lead/Sole Programmer
  • 2014-2015 - Lead Programmer, President
  • 2015-? - Team 1554 Mentor
Independent Public Projects
Developer at Legend Zero LLC.
Java/C++ Programmer
Last edited by MatthewC529 : 29-01-2015 at 21:29. Reason: Troubleshooting is usually easier with more data.
Unread 29-01-2015, 21:27
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Please post the log file from the installer, which is in the log directory in the tools folder.
Unread 29-01-2015, 21:54
AKA: Seiji Shaw
Rookie Year: 2014
Sorry, I can't find any log file. There isn't a log folder within the tools directory. Maybe there could be something to be derived from that?
Unread 29-01-2015, 22:30
AKA: Seiji Shaw
Rookie Year: 2014
I tried everything again, following the instructions to the letter. Now I just get a blank white window. Still no log file though.
Unread 30-01-2015, 09:22
WPILib Developer
FRC #0190
Rookie Year: 2010
How are you running the installer? There's no way that a log is not being generated somewhere, it would crash on startup if it couldn't make a log file.
Unread 30-01-2015, 17:56
AKA: Seiji Shaw
Rookie Year: 2014
I am running the installer from the "user_directory"\wpilib\tools\ with Java(TM) Platform SE Binary. (my default is to open them in WinRAR, so I need to select the option instead.)
Unread 30-01-2015, 19:53
AKA: Seiji Shaw
Rookie Year: 2014
Okay, I just figured everything out. I performed the install with another computer, and it worked perfectly. (There must be something wrong with the other one)
Thank you so much for your help!
Unread 01-02-2015, 08:22
JohnCStewart JohnCStewart is offline
FRC #3489 (Category5)
Rookie Year: 2014
JohnCStewart is an unknown quantity at this point
We had the same problem. The documents say JRE 8u11 for the computer. If you have java updates then you could be on a higher version.
To fix we downloaded 8u11, uninstalled current Java JRE from the computer, disconnect from the Internet, installed Java JRE 8u11 on the computer, opened Java Control Panel and unchecked auto update - then never check button, reconnected to the Internet.
We were then able to install the JRE on the RoboRIO.
