Go to Post Anything worth analyzing is worth over-analyzing. And anything worth over-analyzing is worth hyper-analyzing. Ready, go! - Michael Hill [more]
Unread 29-01-2015, 20:19
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
Rookie Year: 2012
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Drift on ADXRS453 Gyro
Our team has been trying to use the ADXRS453 gyro (datasheet), with this board (http://www.digikey.com/product-detai...53Z-ND/2700448.
We got SPI communication working pretty well, we think. We're getting data from the gyro, in the format we expect. But while at rest, the sensor returns apparently random values between ~0.3 and ~0.8, averaging around 0.6. We tried using a calibration routine, which samples the rate while at rest to find an average drift, but the amount of the drift seems to vary depending on how fast the gyro is rotating, with the result that even with the calibration the gyro results are not usable.
We're displaying the raw 1's and 0's from the gyro on the SmartDashboard, and they show the drift, so we can be pretty certain the issue doesn't have to do with how we process the data. The status bits always indicate "valid sensor data." Our code on github (relevant files ADXRS450Gyro.h and ADXRS450Gyro.cpp) if you want to look at that.
Does anyone have any idea how either to fix this, or to compensate for it? As it is we can't really use the gyro for anything. The ADXRS453 is supposed to be a fairly precise gyro, so I assume that there's a way to get useful data from it. Any ideas?
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 29-01-2015, 21:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Drift on ADXRS453 Gyro
We are using the same gyro. We use periodic tasks and run a fast loop to sample it 600 times and average the samples. I believe we're running it at 500 microsecond loop times.
You then need to take that and subtract the value you get from every reading that the gyro supplies - we currently drift at around 1 degree per minute (or so).
Unread 29-01-2015, 21:17
alopex_rex's Avatar
AKA: Scott Morton
Rookie Year: 2012
Thanks for the suggestion--I'd like to give that a try. How do you get it to loop so quickly? Do you start another thread? We tried to do that early on, using WPILib's Task class, but gave it up when we were having trouble. (The Task runs a function that cannot be a member function of an object, which makes it really hard to integrate into our program.) Is that a worthwhile path to pursue? Or is there a better way of doing it?
Unread 07-02-2015, 12:05
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
I took a function posted by the RatPack and improved it a bit. The drift is more than acceptable.
https://github.com/FRC1296/RHSRobot2.../ADXRS453Z.cpp
Enjoy
Fast, cheap or working - pick any two!
