Go to Post Half your robot could be broken, some drive chains snapped, a drive motor burned out, etc... and your WCD will still be trucking. - AdamHeard [more]
Unread 30-01-2015, 10:21
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question New F310 Gamepad VI Dashboard issues
Dear CD,
I have created a new, F310 Gamepad VI based on the existing Prepare Joystick Data for Displays.VI
to display the gamepad axis and buttons on the dashboard.
I have looked at the examples and read through some CD postings but cannot get it to work properly.
I have wired Y=axis 1 and Y=axis 5 to what I think should be the right inputs for the dashboard display.
Any help in determining what needs to be changed to make it work would be appreciated. I've beaten
this horse for more than it's fair share of time and effort. I'm missing something very basic here.
I have attached a PDF with Labview implementation pictures.
Regards.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 30-01-2015, 10:31
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: New F310 Gamepad VI Dashboard issues
It looks like you are missing a wire to "Cartesian Data" in Prepare F310 Gamepad Data for Displays.vi
Also Z Axis in the same VI is wired to array index 6 (unwired will be previous index of 5 + 1)
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 30-01-2015, 10:45
marccenter's Avatar
Team Role: Coach
wt200999,
1) Good catch. That's very interesting that I did not break that link (I copied and pasted the original VI as a basis) but it must become broken when being rewired. Huh.
2) I'll move the z-axis in my next update when I get home tonight for more testing on my test bench. I'm still a little confused because I would expect the connection to go to Axis 2 on the gamepad in the existing setup but it goes to Axis 1.
Marc Center
Unread 30-01-2015, 11:38
wt200999's Avatar
Texas Instruments
AKA: Will Toth
As a sanity check for which axis should correspond to which array index, you can view the output on the USB tab on the driver station, just remember that they are 1 indexed there, and LabVIEW is 0 indexed. Also if you probe the axis array you will see what data is actually being passed through and you can compare to what the driver station sees.
