Go to Post All in all, you get what you celebrate. The more we celebrate the under-served parts of our team the more students step up and make that part great. - Alpha Beta [more]
Unread 30-01-2015, 13:14
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
pic: 80/20 Flanged Button Head Fasteners
Unread 30-01-2015, 13:15
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: pic: 80/20 Flanged Button Head Fasteners
Yup, flanged screws are great for retention on the ends of shaft. Also dropping a washer into the depths of your robot is never fun. We buy ours at Mcmaster.
http://www.mcmaster.com/#91355a080/=vozj62
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 30-01-2015, 14:08
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Totally missed these! What a headache saver....thanks, Greg.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 30-01-2015, 15:02
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Note that you can strip the hex out of a button head much easier than out of a socket head, especially when the screw is retained with Loctite as should be done on a spinning shaft like this. We had this problem numerous time on our drive last year and have since switched to socket heads with washers. If only socket heads with flanged didn't cost $4 PER SCREW.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 30-01-2015, 15:07
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Assuming you're using a reasonable size like #10-32 or larger, you're putting some mean torque into the bolts, using junk wrenches, or using junk bolts. We haven't had issues with buttonheads stripping out.
#8-32 and smaller on the other hand, much easier to strip.
Unread 30-01-2015, 15:53
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
I've never stripped out a hex socket screw, button or socket. Maybe getting some new allen keys could help.
Unread 31-01-2015, 07:47
AKA: Dana P. Henry
Don't use the ball end of the allen wrench. If the straight end is getting too worn, grind it shorter.
Unread 31-01-2015, 12:24
nathannfm's Avatar
AKA: Nathan
FRC #3940
Standard 10-32 black oxide from McMaster...I can't comment in the meanniss of the pit crew last year , but I will take a close look at our wench tips, I know some of them are at least 10 years old...
