Go to Post One day the code will be written first, and then a robot built around it - dag0620 [more]
Unread 30-01-2015, 15:08
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Rookie Year: 2013
Asymons is an unknown quantity at this point
Where to buy Omni Wheels 6"
Hello Everyone,
Our team was a little late in purchasing some 6" Omni Wheels from Vex Pro, and now we cannot find them anywhere. On their main site it is sold out and every reseller either does not have the wheels in stock, or they do not sell them in the first place.
On our robot, we planned to have two unpowered omni wheels in the front of our robot powered by some wheels with rubber treads.
Does anyone know of another type of wheel that would preform like an omni wheel used in our purpose? Or maybe, another brand other than vex pro that has these types of omni wheels that can hold about a 200lb load. Thank you for your help.
Unread 30-01-2015, 15:09
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
Re: Where to buy Omni Wheels 6"
AndyMark sells a 6" omni wheel
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 30-01-2015, 15:11
Team Role: Driver
Rookie Year: 2013
Thank you for the response. The only problem is that it has a 50lb load max.
"Load Capacity: 50 pounds (rollers don't spin past this weight)"
Unread 30-01-2015, 15:12
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Never mind. Please delete.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 30-01-2015, 15:15
BenDSterling's Avatar
Happy Birthday! BenDSterling BenDSterling is offline
Alumni, Mentor, Volunteer
FRC #6325 (Reset Robotics)
Rookie Year: 2011
BenDSterling will become famous soon enough
They have a 50 pounds max per wheel. So, if you are using 4 wheels, you have a 200 pound max. The robot weight limit is 120 so you should be fine.
Lead Mentor: FRC Team Reset Robotics (#6325)
Mentor: FTC Teams #9686 & #10396
Head of AV for Georgia FIRST Robotics
FTC South Super Regional planning committee member
Unread 30-01-2015, 15:23
Team Role: Driver
Rookie Year: 2013
We are only using two in the front, where the totes will be held. So for us it would be a max of 100lb, and if we are carrying 6 totes, that's approximately 48lbs + other mechanisms that would be present. It would be most preferable to have at least 100lb load per wheel then going off of your identification of the distribution of mass on the robot.
Unread 30-01-2015, 15:24
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
If they're unpowered, why not opt for a different size Omni wheel in that location? When functioning essentially as a caster, the diameter shouldn't matter so long as the wheel is touching the floor. It may require some modification to your bearing/axle mount, but depending on your design that may not be a big deal.
Alternatively, you could double up on the AndyMark omnis to further distribute the load on each wheel.
Unread 30-01-2015, 15:32
Team Role: Driver
Rookie Year: 2013
Thank you for the suggestion. Our design may not be able to double up on the wheels, but I will ask our mentor if incorporating a difference wheel size would work for our design of the robot. I shall update the post once I get his answer. Thank you
Edit: He said if there are no alternatives to getting 6" wheels to match we may go with the 8" ones. The main concern is our robot and how it may not be parallel to the ground. Also we don't want to do the machining for the 8", we would like to stay away from machining it as much as possible.
