Go to Post Just a modest request for folks NOT to put 3000-pixel-wide pictures inline in the forum. A link to the big picture works just as well while keeping the text readable. Thanks. - Rick TYler [more]
Unread 30-01-2015, 16:37
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
Motor Controller issue
We have a Jaguar hooked up with the 2015 PDP and the roboRIO, input voltage is 12.5 V and output is 3.4, we also tested a Talon SR and it's output is 5.4 volts.
We are wondering why?
Unread 30-01-2015, 18:09
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Motor Controller issue
Sounds like your PWM signal is positive and less-than-full. Talon SR LED can give you a sense of how much throttle you are commanding (see Section 5 in Talon SR User's Manual). What is your expectation exactly?
Unread 30-01-2015, 18:14
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
Do you have the correct motor controller selected in your software? There are differences in the PWM signals for the motor controllers.
Unread 30-01-2015, 23:21
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
You are going to have to tell us what you expected to be the result of this. What PWM/CAN signal were you sending it, or were you sending it any PWM/CAN?
Unread 31-01-2015, 11:07
FRC2501's Avatar
We were expecting a full forward (that should be 12V), we did select the correct motor controller for each test in our code
The LED was blinking so our PWM wasn't full, even though the code was telling it to be full, we will try calibrating then get back to you
Unread 04-02-2015, 09:30
FRC2501's Avatar
We calibrated all of our Talon SRs and now they give a full 12.55V output, we haven't tried a Jag yet but we only plan on using Talon SRs on our robot
