Go to Post The rule is the rule because it is the rule. - dtengineering [more]
Go Back   Chief Delphi > Other > VEX
Unread 30-01-2015, 17:08
otterpod's Avatar
otterpod otterpod is offline
FRC #3659 (Patriots)
Team Role: Student
Rookie Year: 2013
otterpod is an unknown quantity at this point
Vex Claw doesnt open all the way
Ok so we're working on a clawbot for the 2015 VEX competition and we're running into a problem with opening/closing our claw. At first, our claw worked perfectly fine and was able to carry various items of varying weights, until one afternoon our claw opened but didn't close. We tried three things, replacing motor, switched axles, and adjust axle. Now our claw is only able to open a third of the way and close. I dont know if its a programming issue or a faulty motor or maybe the claw's assembly
Unread 30-01-2015, 19:40
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Vex Claw doesnt open all the way
of those 3 possible root causes, which is the easiest/fastest to test and rule out?
also, pictures/videos are ALWAYS going to get you better help and advice.
Unread 30-01-2015, 20:11
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
Rookie Year: 2011
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
If the motor / servo is removed will it actuate by hand smoothly?
There is a return spring in the claw that might have broken or come out of its seat. Or there is a broken tooth on the gear teeth on one or both of the pinch arms. Also check the drive gear from the motor shaft..
All of this leads to....
Take apart the claw to verify.
Good luck with it!
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 31-01-2015, 18:38
otterpod's Avatar
Team Role: Student
Rookie Year: 2013
Thanks guys, we'll look into the mechanics (including claw assembly), program, and controller to see if we find anything. Thank you so much
