Go to Post Actually, I forsee two [buttons]: Fire and "Thats the opponents target, you dumb robot" - devicenull [more]
Unread 31-01-2015, 12:37
wildaburk3160 wildaburk3160 is offline
FRC #3160
wildaburk3160 is an unknown quantity at this point
CAN Firmware Update Mandatory?
Our team is trying to run a compressor with one solenoid, and both are wired into the PCM. However, we can't get it to run. Our compressor is wired as it should be, but our compressor isn't doing anything.
The Status light on the PCM is strobing red, which according to http://crosstheroadelectronics.com/PCM%20User's%20Guide.pdf
means that the problem is that there is no CAN communication.
We are not planning to implement CAN at all this year, but I have been seeing some things about updating the PCM firmware. Do we need to update the PCM firmware to be able to run our compressor, even though we have no plans of implementing CAN?
Unread 31-01-2015, 12:47
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: CAN Firmware Update Mandatory?
You need the PCM firmware update if you use pneumatics.
However, you won't be able to update the firmware unless you first fix your CAN wiring so the PCM can be talked to.
The PCM receives all it's commands via CAN.
For development the PCM will operate out of the box with the firmware that it came with, so the update isn't immediately necessary to get it to stop strobing red.
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
The PCM communicates over CAN. How were you planning on controlling it?
PCM wiring is in this doc: http://wpilib.screenstepslive.com/s/...control-system
Firmware update is here: http://wpilib.screenstepslive.com/s/...ribution-panel
Code depends on language.
The rules also require the PDP CAN to be attached to the roboRIO.
Unread 31-01-2015, 12:49
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
The PCM is a CAN device, you have to wire it to the RIO CAN bus. see http://wpilib.screenstepslive.com/s/...anual-id=24166. PDP also should be wired since it has the termination resistor.
Unread 31-01-2015, 16:26
FRC #3160
Now that the PMC firmware is updated, the Status light is flashing green. We have a solenoid being successfully activated by a button push on the controller.
But our compressor won't turn on. We've followed all the instructions as far as wiring goes, with the only deviance being that we used regular black and red wires instead of the green and yellow "CAN" wires.
We tested the Compressor Out ports on the PCM and we don't get any voltage back, even though the rest of the PCM seems to be working without a problem.
I am at a loss as to what the issue is. So, does anybody have any ideas?
Unread 31-01-2015, 16:34
Just Itinerant
You have a pressure switch wired in alongside the compressor outputs on the PCM?
The PCM won't try to power the compressor unless it can detect a pressure switch connection.
Unread 31-01-2015, 16:45
FRC #3160
We do have a pressure switch wired in.
Unread 31-01-2015, 16:47
Just Itinerant
Is the CAN ID of the PCM set to 0?
Unread 31-01-2015, 16:54
FRC #3160
I can't say for sure, because other programmers were the ones who upgraded the firmware. How would I be able to check?
Unread 31-01-2015, 17:20
Just Itinerant
Use a web browser and go to roboRIO-3160.local
You'll see PCM on the left, click on it and the CAN ID will be at the top of the resulting page.
Unread 31-01-2015, 17:27
FRC #3160
I tried going to this address but only ended up doing a google search and not getting me anywhere.
Edit:
I realized I should probably have my roboRIO on. I turned it on and made it to the page. Yes, the CAN ID is 0.
Unread 31-01-2015, 17:56
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You can also verify firmware versions on the diagnostics tab of the driver station.
Unread 31-01-2015, 19:39
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
Rookie Year: 2010
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Do you have code that starts a compressor? In Java, you would construct a Compressor object in some initialization code and then call start() on that object in your autonomous or teleop code.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 31-01-2015, 20:27
That's not needed in 2015. Just construct a solenoid on the PCM and you should be all set code wise.
