Go to Post Hmmm, the Michelangelo method of robot building. Just cut away anything that doesn't look like a robot. - GaryVoshol [more]
Unread 01-31-2015, 01:45 PM
Orthofort's Avatar
Orthofort Orthofort is offline
FRC #2832
Rookie Year: 2013
Orthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to all
SFX Dashboard Problems
Our team has been having problems trying to use the SFX Dashboard. Specifically, there are problems like it not closing properly, and more importantly, we cannot load any saved layouts that contain any commands on them.
Anyone else had any similar problems? Is it just some weird anomaly that we screwed up on?
Unread 01-31-2015, 05:44 PM
DCRich DCRich is offline
Mentor
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
Re: SFX Dashboard Problems
Yes - Team 2180 just gave the SFX Dashboard a try today and we found exactly the same problems. Especially the loading issue is annoying. We had to rebuild the dashboard several times and each time, it would save correctly, we could see it in the correct folder and when you request an OPEN it locates the file correctly based on its extension but nothing is loaded.
Very strange. At this point I am going to toss it back onto the heap of "you get what you pay for" Unsupported software is just that -- unsupported.
Unread 02-01-2015, 12:59 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
(SFX developer here)
Interesting. Could you send me the file? Also how is it "not closing properly" ?
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 02-14-2015, 06:00 PM
prubic's Avatar
prubic prubic is offline
Team Member
AKA: Petra Rubic
FRC #2135 (Presentation Invasion)
prubic is an unknown quantity at this point
Our team has been having similar problems. Once we save our layout on SFX dashboard and try to load it later with the DS, the new layout does not show up. We tried saving it a couple of times, but every time we tried to load it, it would not show up the new layout.
Unread 02-14-2015, 08:32 PM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
SFX is incredibly buggy and I refuse to use it for reasons such as this -- SFX may have more fancy controls but how useful are they if they're unstable?
Welcome to SFX.
Unread 02-14-2015, 09:45 PM
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
Rookie Year: 2012
cstelter will become famous soon enough
My son was lead programmer for our team last year and he managed to make SFX work well enough to us it. We used it a bit this year but also found problems trying to save. We also had problems with PIDCommands appearing on the SmartDashboard side, but *not* with a green play button. At that point we switched to normal smartDashboard and we haven't gone back.
Not sure if SFX is buggier this year, or if my son had some tricks to manage it last year. He's off at college 9hrs away so the team hasn't been able to take advantage of his skills.
Unread 03-28-2015, 01:36 PM
Spaghetti's Avatar
Spaghetti Spaghetti is offline
FRC #0488 (XBot)
Rookie Year: 2011
Spaghetti is an unknown quantity at this point
Has anyone been able to re-open saved layouts in SFX yet? We've also had to go back to the original SD because of this issue even though we really love all of the new features in sfx.
Unread 03-31-2015, 05:14 PM
byteit101's Avatar
I finally found a stack trace of this and was able to reproduce it. The short answer is its due to the label decorators. if you remove them, it works fine. The long answer is much more complicated and appears to be a bug in JRuby's reflection process if its running inside a Jar (as sfx is currently packaged). I've attached an exploded version of SFX here, but it requires you to run it via the command line, though I added a bat file and sh script so it may work by double clicking, but I haven't tested. Also to keep this file under CD's limit you have to download jruby seperately, but there are instructions in run-instructions.txt
Watchdog.Kill();
