Go to Post FIRST is not all about the robot, it's about the experience. Don't sour yours by whining about it later. - StephLee [more]
Unread 31-01-2015, 14:02
2386programming 2386programming is offline
FRC #2386 (Trojans)
Rookie Year: 2011
2386programming is an unknown quantity at this point
Inverting Axis
Hello, I am trying to find a way for when our driver starts reversing with our mecanum drive robot, the rotation axis gets inverted.
Unread 31-01-2015, 17:22
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Inverting Axis
Show us what you have first so we can suggest different approaches on how you can accomplish it.
Unread 01-02-2015, 10:36
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liason
AKA: Ryan
FRC #1902 (Exploding Bacon)
Rookie Year: 2013
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
Re: Inverting Axis
I'd suggest multiplying the axis you want to invert by -1. Example code:
Code:
if (reversing) { //Put whatever code you use to detect if you're reversing here
     myMotor.set(joystick.getYAxis() * -1); //Set a motor to the inverse of the Y axis.
Unread 02-02-2015, 11:41
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Inverting Axis
Code:
You can also just place a - in front of it.
Code:
     myMotor.set(-joystick.getYAxis()); //Set a motor to the inverse of the Y axis.
Unread 02-02-2015, 11:46
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Inverting Axis
Code:
Is this just a matter of aesthetics, or does it actually generate more efficient code?
Unread 02-02-2015, 11:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Inverting Axis
Code:
I'm not sure about Java, but I do know that with traditional compilers, it is more efficient - changing the sign on a number is a much simpler operation, usually done in a single clock cycle. Unless the compiler is doing serious optimization, multiplying by -1 is a full floating-point multiply.
Unread 02-02-2015, 12:02
Ether's Avatar
Rookie Year: 1969
Re: Inverting Axis
Why would you consider that to be a serious -- rather than a simple and obvious -- optimization?
Unread 02-02-2015, 12:06
Flywheel Police
Re: Inverting Axis
That is a question I do not know the answer to. I'm assuming that it is just aesthetic. You are technically using the unary minus operator in both situations because the - in front of the 1 is technically inverting the value of 1.
It is however better practice to place the - in front of the variable instead of multiplying by -1.
Unread 02-02-2015, 12:49
Ether's Avatar
Rookie Year: 1969
Re: Inverting Axis
I share your opinion on this matter1, but to move out of the realm of individual opinion: Is there a widely accepted code formatting standard that states this explicitly?
1for aesthetic reasons and to discourage the compiler from generating a floating-point multiply
Unread 02-02-2015, 13:05
Flywheel Police
Re: Inverting Axis
It is known.
I do not know of any source that explicitly states it, and I haven't found one in a quick Google search. It's just the way I learned and it is the way I do it at work.
Unread 02-02-2015, 13:26
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Re: Inverting Axis
It's simple and obvious to a human, of course. If things were obvious to computers, programming them would be much easier.
OBTW, you pass the Turing test.
Unread 02-02-2015, 13:37
Ether's Avatar
Rookie Year: 1969
Re: Inverting Axis
It's simple and obvious to a human, of course. If things were obvious to computers...
You are claiming that particular optimization isn't obvious to a compiler. In fact, you implied it would be difficult (serious optimization). Please explain your reasoning for that.
Unread 02-02-2015, 13:51
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Re: Inverting Axis
I did a bit of Googling, and it does seem that several optimizers will generate the same code for both cases. Optimizers appear to have come a ways since I last paid close attention.
It still makes sense to me to ask for -x (or 0-x) rather than -1 * x. Provided that the code is equally (or arguably better) readable by people, why not give the computer the simplest directions?
Unread 02-02-2015, 13:59
Ether's Avatar
Rookie Year: 1969
Re: Inverting Axis
It still makes sense to me to ask for -x...rather than -1 * x
Nobody is arguing otherwise.
..why not give the computer the simplest directions?
Because "simple" is subjective and a matter of personal preference.
That's why I asked if this (very reasonable, in my opinion) use of the unary operator in this case might be part of a widely-accepted Java coding standard that could be referenced in support of the recommendation.
  #15   Spotlight this post!
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Re: Inverting Axis
For an example where the simpler code is not easier to read:
Logically, you want to do a conditional:
if (c is between a and b, and you don't know whether a is larger or smaller than b) then...
Human simpler (use this!):
if ((a<b) && (b<c) || (a>b) && (b>c)) then..
Probably machine quicker, but don't use:
if ((a-b)*(b-c) > 0) then..
