Go to Post Let the team grow, let them fail, let them learn and always be ready to lend a helping hand. I think that's the best way to help rookie teams. - Justin Montois [more]
Unread 31-01-2015, 16:07
jSoft jSoft is offline
GG Hirez
AKA: J.R.
FRC #4918 (The Roboctopi)
Rookie Year: 2013
jSoft is on a distinguished road
Unhappy Dashboard output in Labview 2015
Hi everybody, I'm having issues getting limit switches to show up on my dashboard.
Here is the code for the dashboard:
http://gyazo.com/a29bbc6d6b4c5edeba50801bc4a0fb1e
And here is the code in our labview project:
http://gyazo.com/b5a6dee995f634358914a80a857bc770
Can anybody find any issues in this code? Thanks!
Unread 31-01-2015, 16:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Dashboard output in Labview 2015
Is the Dashboard's SD Read in a loop? If it's outside the main While loop, it will only run once as the Dashboard starts.
You actually don't have to put an SD Read in the Dashboard program. If your indicator has the same name as the SD Variable, and if it's in the Custom (or Basic) tab, it will reflect the value of the variable automatically.
Unread 31-01-2015, 16:45
GG Hirez
AKA: J.R.
Rookie Year: 2013
Yes my dashboard code is in a loop. It is in loop 1 in the dashboard code. Is that correct?
Unread 01-02-2015, 10:03
You may want to use the dashboard's variable tab to see whether the variable is being set on the robot, and you are having issues with the DB, or whether the robot is having issues setting the variable the way you expect.
To summarize what I'd check in your code. Verify that the limit switch code is setting the SD variable when you expect. Make sure it is in teleOp or a loop and is executing repeatedly. Then I'd probably just place the LED in the Custom tab and delete the diagram read code that updates the LED.
Greg McKaskle
